06-12-2014, 03:24 PM | #1 |
need advice on vortec heads on goodwrench!
I have an as is goodwrench 350, Im not sure of the power output, but I know I would like to put some more pep in her step. I dont have a real idea of what I want. But then I found a local listing for:
Vortech chevy heads 12558062 Screw in studs Dual springs moly retainers 10* locks Self align rockers and* adjusters Center bolt aluminum* valve covers Lunati Voo Doo hydraulic cam p/n 60105 with lifters Edelbrock aluminum intake for the vortech heads I know the cam is wildly to big for the proposed setup. But I am morw interested in the other parts and sell the large cam and find a more appropriate one. the old girl is a 69 c10 longbed. Rebuilt original 350 trans. Stock rear end, whatever gears it is. And was my daily driver but now just on weekends for fun. so the question is.... should I take advantage of this listing or should I find another route to go? I have never attempted a head or cam swap but I have always wanted to learn! thanks for any feed back!!! |
06-12-2014, 03:52 PM | #2 |
Re: need advice on vortec heads on goodwrench!
If it is the standard Goodwrench 350 then it should have 260 horsepower with 4 barrel and headers. They also make a 290 horse version. The Vortec heads will bolt right up and will raise your compression ratio about a point. You would be in the 9.5:1 range. Maybe change to a Comp Cams 268H cam. Very well rounded street cam that you can still use your stock converter with or you can bump up to a 270h before you have to upgrade your torque converter. Wouldn't hurt to match the springs to the new cam as well.
This is all my opinion of what I would do if it were mine. It isn't hard to do a cam/head swap. Just take you time and check and double check everything.
Bud |
06-12-2014, 04:23 PM | #3 |
Parts and more parts
Along with the vortec heads bumping your compression ratio up a little, the flow characteristics fo the vortec head design is one of the best you can find in a street engine. This combination can easily change that 260 horse engine into a good solid one that would be hard to beat. With the right cam and exhaust, you could easily have a 350 to 375 HP performer.
Frank |
06-12-2014, 06:37 PM | #4 |
My crate motor is a pretty basic 350, .030" over, flat top pistons, 9.5:1 compression ratio, with Vortec heads. 600cfm 4 barrel and headers it made 382 HP and 402 TQ on the engine dyno. Runs real strong in the truck, not sure I would want much more with stock suspension on the street.
Choose a decent cam for the heads and you should be in really good shape.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
06-12-2014, 07:47 PM | #5 |
What questions should I be asking the seller?
Thanks AGAIN! |
06-12-2014, 09:59 PM | #6 |
Lattimer which intake and cam did you use?
Thanks Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
06-12-2014, 10:05 PM | #7 |
You need to ask if the heads are duel pattern for the intake bolts so you can use old school intake or have to buy new style for vortech only.
06-12-2014, 10:33 PM | #8 |
You will not regret the vortec head swap. The heads won't be dual pattern being 062's, they are regular production heads [not that there is anything wrong with that] the Vortecs will give just about any small block 40 horsepower over the other heads and just about every magazine except better homes and fast fords have proven that. The Comp Cams 268H cam would be a great choice for your good wrench motor I have run a bunch of them and never been unhappy with them and with the vortecs even better. Jim
06-12-2014, 11:43 PM | #9 |
They both came with the motor. Intake is an aluminum Edelbrock performer knock off.
Cam specs Hydraulic Flat Tappet Duration @ .050'' Lift: 224 Intake / 230 Exhaust Lift: .480'' Intake / .486'' Exhaust Lobe Separation: 110° Its got a decent lope but still makes 14" vacuum at idle. Supposedly ok for 1800-2200 RPM stall converter, but I run a manual so didn't worry about that.
06-12-2014, 11:45 PM | #10 | |
If they are not rebuilt, thats fine as long as the price reflects it. Just expect to have to do a full rebuild on them.
06-13-2014, 12:11 AM | #11 |
RAT1968 '68 Cab/'71 Parts
I have a newly rebuilt set of 062 Vortec heads that are sitting and waiting while I'm itching to do a motor.
Likely, they'll go on something like a Goodwrench before the 383 gets built. When they do (go on the Goodwrench), I'm going for the 268H cam. I had the heads...or, I should say, my buddy had them. I had new springs, valves and pocket porting done to them. When I took them to the machine shop, I left the 195 intakes and moved up to 160 exhaust. With me taking in the raw heads with the old stuff still attached (valves, springs, rockers), I'm in 'em about $575. Still have to get an intake manifold. And, I'm not sure my 625cfm carb will be up to the task.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 06-13-2014 at 01:29 AM. |
06-13-2014, 08:06 AM | #12 | |
"Negative people always seem to have a problem for every solution" |
06-13-2014, 11:39 AM | #13 |
Thanks for the info and the cam recommendation. I am in touch with the seller and getting some information. The asking price is $650. But how do I visually determine the condition of the heads and if they need to be gone through?
06-13-2014, 11:51 AM | #14 |
Also, I have heard of some using the xe grinds? Is that something to consider?
06-15-2014, 09:51 AM | #15 |
You might also want to try and find a set of L98 Corvette heads. These aluminum heads were on the 86-91 TPI Corvettes. They are far more standard than the vortech heads and feature 58cc combustion chambers which gives you a bump on compression. I have a set on my Corvette and have been very happy with them. I had a machine shop do some work and clean them up.
06-15-2014, 10:39 AM | #16 | |
Frank |
06-15-2014, 11:45 AM | #17 |
No argument on the stock L98 heads. I ended up having mine ported and polished up to increase the flow. I have an larger mechanical cal in the Corvette and needed the compression more than anything to help bring up the power. Nothing worse than putting to big a cam on motor without enough compression - just bleeds everything off at the low end.
06-16-2014, 10:31 AM | #18 |
So... the heads are set up for the voodoo cam. Would this mean that the smaller comp cam would need less spring?
06-16-2014, 11:47 AM | #19 |
Like I said before, I would match the springs to the cam so you know that the parts are going to work together. See if he will just sell the heads alone. If you don't want that cam there is no point in you having to try and sell it. I have never had much luck selling used cams.
Bud |
06-16-2014, 01:02 PM | #20 | |
https://sdparts.com/details/scoggin-...-center/sd3816
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
06-16-2014, 01:22 PM | #21 | |
boat-anchor heads........ which I'm running now) to the re-machined and freshened up 062 Vortec heads I have all ready to switch out? I think the Edlebrock intake manifold is a #2116...But I can't remember the number for sure. It would be really great not to spend big dough...Or to get a nice polished one for less that someone with experience can say, "....go for this one".
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
06-16-2014, 01:35 PM | #22 |
I am doing the exact same thing you are doing. I have a base GM crate 350 that is fine, but just needs a little more oomph. I bought a newly rebuilt set of vortecs from a local machine shop for $300 and a lunati 60102 cam kit. The machinist was nice enough to remove and replace the springs and retainers to include machining the bosses down for .500 lift at no additional charge. I bought the Eddy EPS vortec intake also. I plan to get this stuff installed by the first of July. I am hoping it gives me the performance I'm looking for. Good luck to you If you were closer I'd refer to the machine shop I used for a good price on heads.
-Jason USN Retired |
10-21-2015, 06:10 PM | #23 |
I know this thread is old, but you can buy cast Iron Vortec heads for under $700.
http://www.jegs.com/p/Chevrolet-Perf...49896/10002/-1 I think i would do that instead of buying used, unless it's a smokin deal. (I would prefer not to rebuild the heads) |
10-21-2015, 07:51 PM | #24 | |
Posted via Mobile Device |
10-22-2015, 01:41 AM | #25 | ||
San Francisco....$700 Tulsa................$200 Sounds about right! For $200 rebuilt heads, shipping would be well worth it.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
