![]() Join Date: Jan 2012
wtb helper spring brackets
my 1 ton crew did not come from the factory with helper springs. I have located everything, new springs, perches w/plastic sleeves , spacers , and the top pieces. the parts that I still need are the reinforcement brackets that connect the spring perches to the frame . thanks for the help.
#2 | |
Re: wtb helper spring brackets
Yes , thats correct . they are the horizontal brackets that were riveted to the spring perches front and rear . thanks
Ok. I'll check this afternoon & make sure I still have them. I'll follow-up this evening....
The overload-spring brackets I cut off my frame did not have reinforcement brackets (they were just riveted to the side of the frame).
The rear leaf spring hanger did have a reinforcement bracket that was rivited to the bottom of the frame & gusseted the hanger where the bolt went through. Are these what you need? These reinforcement brackets were only attached @ the rear/bottom of the frame. The front hangers did not have any additional gussets/brackets on my dually.
