Old 06-17-2014, 05:58 PM   #1
pbr
O2 sensor
I bought a harness it appears to be a truck harness I am having trouble finding the correct O2 sensors. The sensors I find are the wrong connection for the harness. It seams that the connections for the downstream O2 sensor and the upstream are swapped. I have checked my harness and I have removed the correct O2 sensors.
Patrick
pbr is offline   Reply With Quote
Old 06-17-2014, 06:21 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: O2 sensor
Let me guess, they are Bosch 13944
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-17-2014, 06:49 PM   #3
pbr
Re: O2 sensor
I've looked mostly at the delco ones. My plug is a black female 4 prong square. I can find white ones triangle ones male plugs but not the plug in need. I have seen downstream sensors with my plug but not an upstream one.
Old 06-18-2014, 12:14 AM   #4
littlevictories
Re: O2 sensor
i've seen those as the primary/before cat o2's
but only on a '99 iron headed 6.0l
i think they are the case-ground style.
maybe switch to an easier to find iso-ground and run a ground up the leg int a splice pack?
littlevictories is offline   Reply With Quote
Old 06-18-2014, 12:44 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: O2 sensor
Oops typo I meant the
13444
Old 06-18-2014, 07:03 AM   #6
pbr
Re: O2 sensor
Yes that looks like it. THank you very much.
Patrick
Old 06-18-2014, 01:29 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: O2 sensor
Patrick
No problem, its cheating since I was able to pull that one out the memory banks. The 13444 is Bosch's most price-friendly (both on sensor and connector) heated-circuit 02. Ends up getting used on most swaps.
Old 06-18-2014, 04:58 PM   #8
desertdogg
desertdogg's Avatar
Re: O2 sensor
Yep that's the ones I need too
Trying to get thru my LS swap
desertdogg is offline   Reply With Quote
Old 12-06-2017, 04:01 AM   #9
Harley03joe
Re: O2 sensor
Well I Just Looked For A Heated 02 Sensor For My 87 Chevy R 10 Silverado I Have The 1 Wire 02 I Wanted To Put In The Heated 02 With 4 Wires,,, And Help Here.
And Every Place I Looked It Said >>This part is not compatible with 1987 Chevrolet R10 Silverado Standard Cab Pickup 2-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated.
Do You Have A Part # For Me To Look At ??
Thank You Harley03joe
[/COLOR][/COLOR]
Thank You Harley03joe [/B][/B]
1931 Ford Like New And For Sale
2004 Harley Davidson Heritage Classic
1987 Chevy R 10 Silverado
2007 Azera
2011 Cadillac CTS Premium
Harley03joe is offline   Reply With Quote
Old 12-06-2017, 04:40 AM   #10
ls1nova71
ls1nova71's Avatar
Re: O2 sensor
I'm not sure that's possible. Why are you wanting to do this?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-06-2017, 01:54 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: O2 sensor
Note that my follow up post to the one you quoted shows 13444 as a corrected part #.
Also, these are for LS swaps. It will never show that it fits your R10, because on paper, it does not. Not the same motor, none of the same wiring etc.
You might consider trying in the gen specific sections if guys have more specific advice...but otherwise I've seen these used:
https://www.summitracing.com/parts/CEI-103025/
Old 12-07-2017, 10:02 PM   #12
Harley03joe
Re: O2 sensor
Well I Was Told >> Better Mileage Heats Right Up
2007 Azera
Old 12-07-2017, 10:07 PM   #13
Harley03joe
Re: O2 sensor
Can I Put This >>Caspers Electronics Heated Oxygen Sensor Retrofit Kits 103025 Kit
Can I Put This On My 87 silverado 5.7 ???
Let Me Know Ok
Thank You
Harley03joe
2007 Azera
Old 12-07-2017, 10:10 PM   #14
Harley03joe
Re: O2 sensor
And Thank You For The Info
2007 Azera
Old 12-07-2017, 11:18 PM   #15
ls1nova71
ls1nova71's Avatar
Re: O2 sensor
The time it takes a non-heated sensor to heat up really isn't that much longer, so I would doubt you'll see any noticeable difference In fuel economy.
Old 12-19-2017, 03:30 PM   #16
Harley03joe
Re: O2 sensor
Ok Thanks No Heated 02 Then Thanks
Harley03joe
2007 Azera
