07-11-2014, 10:53 AM | #1 |
Salty Sailor
10 Bolt Problems
I have had a few issues lately with my rear end (on the truck). my passenger side brake drum is self adjusting so much as to cause drag when driving. I tightened the adjuster and removed the "springed flap".
This quick fix resolved the issue, but last time I drove it I noticed the drag again not nearly as bad as before but I know its killing my gas mileage so I don't drive it. I rebuilt the drums about 2 years ago. This rear is from a 90's bodystyle truck, cant remember the exact year. but I had to source the adjusters from a junkyard, so could i be using two drivers side adjusters or what?
86 c-10 Custom Deluxe Savannah, Georgia |
07-11-2014, 11:19 AM | #2 |
Fabricate till you "puke"
Re: 10 Bolt Problems
If properly set up, (1 side is a mirror image of the other), they should not over adjust? With that I will ask couple ? Are the wheel cyls new? The other is on the E-brake....are you sure it is not hanging just a bit on the affected side? longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-11-2014, 12:33 PM | #3 |
Salty Sailor
pictures from the rebuild
this is the passenger side
07-11-2014, 12:40 PM | #4 |
Salty Sailor
drivers side
07-11-2014, 12:50 PM | #5 |
Salty Sailor
My e brake cable on the truck was cut long ago for some unknown reason, so when I swapped in my new rear i just tucked the new cables into the frame.
07-11-2014, 05:16 PM | #6 |
You got the shoes on wrong on both sides.
You need short shoe to the front. |
07-11-2014, 07:14 PM | #7 |
Salty Sailor
haha, whoops. would this cause any issues?
07-11-2014, 08:32 PM | #8 |
Tags |
brake drums, brake shoes, bucannon |
