Old 07-23-2014, 09:26 AM   #1
papsoldblue72
papsoldblue72's Avatar
Question Solid engine mounts.....
Ok I need a little help I got a new set of factory mounts but I think the engine I'm putting together is just gonna rip them .... I have a friend that has had to replace his twice already... I think I need to switch mine out before I even put them in.... Has anyone on here used a solid mount if so what kind and where can I get them ??? All I can seem to find is a clamshell design and mine aren't made that way ....
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 07-23-2014, 09:55 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Solid engine mounts.....
Summitrcing.com take your pick they have dozens of applications
Grumpy old man is offline   Reply With Quote
Old 07-23-2014, 01:03 PM   #3
69chevytrucker
69chevytrucker's Avatar
chain the block down
69chevytrucker is offline   Reply With Quote
Old 07-23-2014, 05:42 PM   #4
Fitz
Make your own or buy the aftermarket mounts drag racers use. Jegs, Summit or Speedway has them. Trans Dapt mounts are a good example but you will have to add a plate to your frame to mount them. You need to be sure you replace the transmission mount as well. You aren't going to like them!
Fitz is offline   Reply With Quote
Old 07-23-2014, 09:16 PM   #5
papsoldblue72
Ok so any of them will work just as long as I get them for a small block 350 ??? Is this what I'm understanding???
Old 07-23-2014, 09:20 PM   #6
papsoldblue72
I thought about it .... It just looks tacky I also thought about a turn buckle just to make it look better... I'm thinking I might just make a homemade front motor plate out of some scrap 1/4" aluminum plate and use the two bolt holes at the bottom front of the block....
Old 07-23-2014, 11:04 PM   #7
69chevytrucker
i did that with my camaro 2 pieces of 1/4 plate and my engine didnt move
Old 07-24-2014, 08:45 AM   #8
papsoldblue72
Thanks 69chevytrucker I think I will just do that ...
Old 07-24-2014, 09:22 AM   #9
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Get the Energy Suspension mounts. You cat rip those .
Tom Vogel is offline   Reply With Quote
engine mount
