Old 08-01-2014, 01:43 PM   #1
68Stepbed
68Stepbed's Avatar
Bolt in 9" for 60-72 trucks at Speedway motors
OK, I haven't been on here much lately, so not sure of this is a repost or old news, but I don't remember seeing it on here anywhere. Speedway motors has bolt in 9" rearends for our beloved trucks.
http://www.speedwaymotors.com/Bolt-I...cks,80935.html
They also have full float 9" housings with Grand National hubs if you're interested.
http://www.speedwaymotors.com/Winter...Ends,1287.html
http://www.speedwaymotors.com/Grand-...-End,6587.html
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-01-2014, 07:07 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Bolt in 9" for 60-72 trucks at Speedway motors
Seems like a lot for an empty housing with some spring perches, especially since you still gotta find axles and a center section. Plus, what is it made of? The old WAR vs N cases discussion STILL is going on.
You can build an 8.8 for less, and be pretty freaking strong. The 9" is heavy, and while very strong, it is "favorited" on name mostly. Plenty of people have snapped the bad-case 9", and plenty have run single digits on fabbed-junkyard 8.8's
Food for thought for the wallet.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-02-2014, 05:31 AM   #3
andrewmp6
A bare housing made to any size starts at 295 http://www.quickperformance.com/QP-B...g_p_16025.html
andrewmp6 is offline   Reply With Quote
Old 08-02-2014, 02:55 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thats for a "reconditioned" unit. (aka junkyard put through a parts washer).
Its not the worst thing since its harder to find some 9's these days, but your not exactly getting something like a Fab9 for that money.
Old 08-03-2014, 12:46 AM   #5
andrewmp6
Yeah finding a used 9 inch is getting harder lately,Ford dropped the 9 inch in 86 for the 8.8 and finding anything that old in a junkyard today is rare here.The 8.8 ain't bad and made in a ton of different widths.
Old 08-03-2014, 04:18 PM   #6
68Stepbed
68Stepbed's Avatar
The 8.8 is almost a carbon copy of the GM 12 bolt, though. It still uses c-clips.
Matt
Old 08-05-2014, 12:55 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
It looks similar, and is designed to a very similar spec. The 8.8 has 31 spline axles, different # of bolts on the pan, and slightly different optional gearings. The bearings etc are similar but not the same, and the c-clip setup is a little different. From what I've read, its also much different when trying to eliminate the c-clips on the 8.8 rears that were disc equipped (and those parts are NOT cheap)
