08-08-2014, 03:20 PM | #1 |
Air ride question
Is there a noticeable ride improvement with air? Does the air ride smooth it out quite a bit compared to shocks?
-Jason USN Retired |
08-08-2014, 05:55 PM | #2 | |
Re: Air ride question
A HD high rate (stiff) coil & high pressure gas shock set-up compared to a light duty (soft) coil & low pressure shock would yield different ride quality but are the same type of suspension. So when you compare air ride's 'improvement', there could be no change/barely noticed (lt duty/low pressure shock) or significant difference (HD/high pressure shock). Regardless of spring type (leaf, coil, or bag), you need the correct shock to control the springs oscillation.
08-11-2014, 02:03 PM | #3 |
Air bags with a good quality shock with rebound adjustment rides better then springs...
