Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 08-14-2014, 10:30 PM   #1
bts2
1970 C50 Brakes
Hi all,
new to the forum - I've got a 1970 Chevy C50 dump that I acquired with some property. It's been sitting for a while and I am going through it to get it running and stopping. Engine is almost there - still going through carb and sticky valves - bad old gas.
Now I am over to the brakes - I have none - pedal to the floor. Booster falling apart. Before I start getting into some bucks for obscure parts, I read in another thread to consider replacing the single MC and remote booster with a standard firewall mounted dual circuit MC/Booster.
Is this a good idea? any pointers on years and parts from donors? How do I ensure I maintain the load capacity of the truck (with the DMV?)
Thanks for your help,
BT
bts2 is offline   Reply With Quote
Old 08-15-2014, 09:17 AM   #2
cerial
cerial's Avatar
Re: 1970 C50 Brakes
Breaks are the most important part of a truck with steering coming in a close second.
Running Hydroboost is highly recommended.
But, I can tell you right now that the DOT does not like any modifications so you need to ask yourself what you will be using this truck for. On the state level you should contact more then one shop that does inspections to get a unbiased opinion to see if your are going to have trouble with the updated and improved system.
As far as maintaining the pressure with hydroboost. You will. If you are using vacuum/hydro then hydro boost will make enough if not more pressure then the stock system.
There is nothing wrong with running vacuum/hydro. It is a good system and can be maintained easily enough. Just be glad you have a Chevy. I have restored a few old trucks to stock "show points" condition before. Short version is that I will never do another air/hydro Power Wagon again. The less expensive dual circuit in my current 67 "points" project was bought based on the nightmare finding air/hydro parts and getting bent over by the big 4 who still sell parts.
I would suggest moving up a few years when you replace the master cylinder to give you a dual circuit and don't think one person except for a points judge at a show is going to say anything bad about the upgrade. The rest of the system is good in stock form. Just replace the wear components and call it done.
cerial is offline   Reply With Quote
Old 08-15-2014, 08:19 PM   #3
colgad
colgad's Avatar
Re: 1970 C50 Brakes
Replace both the vacuum booster and the dual master cyl as a set. Is your booster under the cab or on the firewall? If under trash it and put your new on on the firewall.
Be prepared to spend some cash on the wheel cylinders, there are two for each backing plate and they are large. Your going to need a friend to remove the drums or you will forever have back issues. Replace all of the steel lines, along with the ones that run from the top wheel cylinder to the bottom wheel cylinder.
I have told myself that I will never do this again I am swapping front and rear axle to get disk brakes on my current 67 C50.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 08-15-2014, 08:40 PM   #4
bts2
Re: 1970 C50 Brakes
Should I put the booster on the firewall like a conventional car/light truck - between the pedal and MC? Right now, it's under the cab and it's spent...
Current MC is a single circuit. If I go dual, can you recommend a MC and booster to use - year of donor vehicle?
How would I split the system? The 70 C50's have an odd split where the fronts and one of the rear cylinders is one circuit, and the other rear cyl is the secondary circuit. Do it that way? diagonal? Front/rear?
don't think I'm ready for discs just yet - maybe later... Thanks for the headsup on the drums though - everything on this truck is heavy.
Thanks again,
BT
Old 08-15-2014, 09:43 PM   #5
colgad
colgad's Avatar
Re: 1970 C50 Brakes
Spilt it front and rear.
Yes Booster on firewall
I am using a TopKick Master and booster but I am using hydroboost
Do you have power steering? If so you can use it too.
But Ill look around and see what may work with a vacuum booster
I had a 72 C50 with the booster under the cab and a second master down there too. all though mine was still all one system. Loose one brake seal and it's all over.
Post a photo of your truck! Here is my first one (sold) and my current one.
Old 08-15-2014, 10:19 PM   #6
bts2
Re: 1970 C50 Brakes
I do have power steering so hydroboost would be an option. I want to keep the GVWR if I can and the dump bed and maybe put this thing to use
Nice trucks - I'll get a pic soon - mine's still a little rough...
thanks
Old 08-15-2014, 10:26 PM   #7
colgad
colgad's Avatar
Re: 1970 C50 Brakes
thanks
Thinking about picking this up but I don't know why. But it's just so cool.
http://sarasota.craigslist.org/cto/4582688095.html
Old 08-17-2014, 07:28 PM   #8
mrolds88
Re: 1970 C50 Brakes
Is your MC like this? My C50 has the Hydrovac system. Parts aren't quite as obscure as one might think. I can't speak for the other type setup with the booster on the firewall. I am pretty sure that the pressures are different between the two systems.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 08-17-2014, 07:31 PM   #9
mrolds88
Re: 1970 C50 Brakes
Gak!!! Thats stupid money for that!! It smells of a pickup conversion!!
93 K2500 xcab 6.5TD
Old 08-17-2014, 10:05 PM   #10
bts2
Re: 1970 C50 Brakes
That's a great truck. It's got the right frame and axles, trans and air brakes to not be a pickup, no?
Old 08-17-2014, 10:09 PM   #11
bts2
Re: 1970 C50 Brakes
Yup, same single circuit MC and same 350 small block. Booster under the driver side cab.
I've found most of the parts at Carquest here but since they're all bad on my truck, instead of sinking money into an outdated braking system on a truck where originality doesn't count, thought I'd investigate a more modern layout. Doesn't have to be hydroboost, but that does seem cool- my diesel pickup has a similar layout. I just wanted mostly to get a more failsafe dual circuit system. If I can save a little with a more common booster or a hydroboost, and get better braking, all the better.
thanks
Old 08-18-2014, 10:14 AM   #12
mrolds88
Re: 1970 C50 Brakes
There is a thread or two over on stovebolt that you might want to look at. Here's one. http://www.stovebolt.com/ubbthreads/...gonew=1#UNREAD
93 K2500 xcab 6.5TD
Old 08-18-2014, 12:56 PM   #13
84rzv500r
Re: 1970 C50 Brakes
Funny, I have been to Lutz Fl many times.. my aunt used to live there... I am over in palm beach...
Which year top kick MC and GVWR rating if you don't mind me asking? I have to modify my diver side valve cover on that big Detroit to clear the MC if I use a Hydro-boost and MC from an 87 C-50. Its a little hard to see as the picture is fuzzy but you get the idea.... I have all new brake lines run for a dual line system and just need to figure out this last piece for brakes...
72 GMC K5500 Napco 4x4 8V71/RTO-9513/T-1138
71 Corvette Wide Body 502 Ramjet
83 HD XR1000, 99 HD XL1200S, 84 YAM RZV500R
05 MB E55 AMG, 12 45th Camaro SS stick vert
84rzv500r is offline   Reply With Quote
Old 08-18-2014, 09:17 PM   #14
colgad
colgad's Avatar
Re: 1970 C50 Brakes
Here is the HydroBoost from an Astro I have on my 67 C10. I may try this on my 67 C50 depending on the cost of the TopKick version.
Old 08-18-2014, 09:20 PM   #15
colgad
colgad's Avatar
Re: 1970 C50 Brakes
92 TopKick not sure of the Weight sorry. I have scraped the cab.
Old 08-18-2014, 10:45 PM   #16
84rzv500r
Re: 1970 C50 Brakes
ok,, that what i thought... I run a similar set up on my 71 corvette and wilwood calipers. think the issue will be master cylinder piston size/volume... have seen is the cars and small trucks run 1 inch to 1.125 MC bore and the larger trucks run from 1.250, 1.50, or 1.75 depending on the brake system.
It's a pascal's law thing. I am going with a 1.75 MC and a hydroboost from 87 C-60 that has the same brakes as my truck.
Thanks for the info.
Old 08-19-2014, 08:32 AM   #17
colgad
colgad's Avatar
Re: 1970 C50 Brakes
Yea, that sounds like a good plan. And would like to know how that goes.
By the way my Daughter used to live in WPB now married in Coral Springs.
When I get down that way Ill see if I can drop by, love to the the truck and the vette.
I have a vette buts it's an 04 Z06, not a classic but still a fun car!
Old 08-19-2014, 08:38 AM   #18
colgad
colgad's Avatar
Re: 1970 C50 Brakes
I meant to tell you earlier that what a great job lengthening the bed. Like to talk to you about how you cut it. And did you take the bed sides off the bed floor or did you keep it all together. What are you going to do for flares. I have though of stepside fenders cut down to size and even though I have a fleetside bed also I have thought of having a widened step side.
Old 08-20-2014, 09:37 AM   #19
84rzv500r
Re: 1970 C50 Brakes
I just used a Sawsall and cut it apart... took a while to get it jigged up to weld back together and have the lines look good. i am using parts of the donor box as repair panels and patches for the bed floor. I am trying to decide if I am going to lengthen the inside to match or not... I am planing on mounting the fuel tank in the 28" long front section and have a couple options there... regarding the rear flares. I bought a C-65 Dumptruck and cut the 8" wide front fender flares off to make rear flares from... they line up very well and look good but they are in rough shape rust wise and will require a LOT of metal work to get right... SO if i can find a set of C-60/65 front fenders and lower extensions i will go that way.. I am also looking at using 2006 ish Dodge megacab shortbox dually fenders as a backup plan... I dont like the stepside fender look so I ruled that out early on.
Old 08-20-2014, 02:32 PM   #20
colgad
colgad's Avatar
Re: 1970 C50 Brakes
If you see any more C5X front fenders let me know I like that idea. Tough to find used C50-60 sheetmetal anywhere
Old 08-30-2014, 10:59 AM   #21
bts2
Re: 1970 C50 Brakes
Thanks guys!
I'm liking the hydroboost solution more and more. Looks like 79-87 hydroboost may be the simplest way to go - I don't want to do an axle or spindle swap just yet or should I go ahead and bite that bullet too? Would you do discs front/drums rear? Or can I do a 87 M/C and booster and keep my existing wheels and drums as is?
Thanks again.
Old 09-01-2014, 01:32 PM   #22
bts2
Re: 1970 C50 Brakes
On the 87 C50's , there are a few setups, vacuum boost, hydroboost, and "dual power" vacuum and hydroboost. I think I want to go with the "Hy-power" option which is hydroboost only - how can I learn more about the applications for 87 and if this option is sufficient for my weight rating (22,000 GVWR). Is this hy-power booster driven by an electric motor then on top of the hydraulic feed from the power steergin pump?
Pics would be most helpful!
Thanks guys..
Old 09-01-2014, 07:05 PM   #23
colgad
colgad's Avatar
Re: 1970 C50 Brakes
Thanks guys..
High pressure Hydraulic hose from the pump to the booster to the steering gear.
Low pressure Return hose from the booster to the steering gear to the pump
Old 09-01-2014, 10:34 PM   #24
bts2
Re: 1970 C50 Brakes
Thanks! I'm good with the hose routing, what I'd like to see is the actual hy-power booster and m/c installed on the firewall. Is there no electric motor like on the smaller cars and trucks? Why did GM offer the "hy-power" and the "dual power" options where the dual power also has a vacuum booster?
Old 09-01-2014, 11:29 PM   #25
colgad
colgad's Avatar
Re: 1970 C50 Brakes
Electric motor? I have an hydroboost on my 67 and trust me there is no electric anything on it.
