Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-18-2014, 09:31 PM   #1
67chevysupercharged
67chevysupercharged's Avatar
9 inch conversion question??
I'm currently in the process of trying to swap the 12 bolt in my 67 c10 to a 9 inch and I'm trying to figure out what years and models of Ford vehicles had a 9 inch with the closest dimensions to our truck 12 bolts? I was told that the 9 inch from a late 70's Lincoln is close, but are there any others?
Thanks in advance!
Zak
71 Longhorn 402, PS, PDB, AC, Tach, Posi
67 SWB 6.0 LSX swap, 4/6 ECE Drop (Work in Progress)
2002 Victory Red ECSB Silverado 5.3 (DD)
67chevysupercharged is offline   Reply With Quote
Old 08-18-2014, 10:16 PM   #2
dinnut
dinnut's Avatar
Re: 9 inch conversion question??
I'm putting my 2nd 9" in the truck now. This one is from a 72 torino. It's within an inch of the stock 12 bolt that was in the truck. The first one I put in had a way offset pinion (to the passenger side) and I didn't like how it had my 1 piece driveshaft angled. The first was pulled from a 77-78 bronco. It's about 3 inches wider.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 08-18-2014, 11:15 PM   #3
67chevysupercharged
Ok sweet, I've got some leads on a few rear ends, but I was trying to get an idea of what year 9 inches would be the easiest to swap in.
Thanks dinnut!
Old 08-18-2014, 11:25 PM   #4
71Dragtruck
71Dragtruck's Avatar
I think Moser makes a direct bolt in now, although as you may suspect, easiest or strongest will never equal cheapest.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 08-19-2014, 12:28 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
The first one is a truck housing.
What I started with and narrowed one side to center the pinion. Also had 3.25 tubes.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 08-19-2014, 10:21 PM   #6
67chevysupercharged
I've looked at the moser packages, and I'm trying to decide if it's more worth it to go ahead and just order a complete rear end rather than modify an old 9". Does anyone know what the general price difference would be between buying a new moser unit and building an equivalent strength used 9""? This truck will primarily be street driven with occasional track use, but I want the rear to be able to handle just about whatever I throw at it.
Old 08-19-2014, 11:00 PM   #7
Captainfab
60-66 Nut
The cost of narrowing an original 9" housing depends on how much of the dirty work you do yourself. If you just drop off a complete greasy dirty differential with all the original brackets, for someone to narrow, it's going to cost 'ya. At least that is the way it is in my shop.
Old 08-20-2014, 06:55 AM   #8
PGSigns
PGSigns's Avatar
I have done a bunch of rears for folks and one of the things we saw was bent housings. A few bent from the demise of the donor but most bent from the welding that was done one it. A set of axle tube will move a bunch when you weld on them. So we always put the ends on the housing last after all other welding was finished. Had a 2" ground piece of bar stock that went in the housing to center the ends true with the center section. This made for very easy axle installs and a car that would roll straight and easy. This is the advantage of the Moser housing over a doner and doing a bunch of welding on it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-20-2014, 01:39 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
I ground the weld on the center. Pushed the longer tube in 2" to center the pinion up.
Low budget but...
Old 08-23-2014, 09:10 PM   #10
vidman
vidman's Avatar
My Moser fab 9" with 35 spline axles and Detroit locker.. cost was around 3400.00
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 08-23-2014, 09:16 PM   #11
vidman
vidman's Avatar
Pics
Old 08-24-2014, 08:37 AM   #12
ls64
That's a good looking rearend!
ls64 is offline   Reply With Quote
Old 08-24-2014, 08:11 PM   #13
67chevysupercharged
Thanks for the pics Vidman, that looks great for 3400. Did that price include the cost of the drum brakes as well?
Old 08-24-2014, 08:43 PM   #14
vidman
vidman's Avatar
I used my stock 12 bolt drum brakes. also had 35 spline axles, Detroit locker,Daytona aluminum pinion cover,tapered bearing upgrade, backbrace, 1350 yoke and 3.25 ratio. When bolted it in I ended up with a 3 degree up pinion angle which works out perfect with my 3 degree trans down angle. Very happy with the purchase..
Old 03-10-2015, 01:10 AM   #15
Dudler
I just acquired a 58 inch wide 9 inch rear. I believe it came out of a Torino and narrowed due to the thick wall flat top tubes and flange bolt pattern. It has 31 spline Moser 5x5 axles.
The question I have is due to the thick walled 3.25 inch housing will this be a big issue doing a swap into a trailing arm 68 with a stock 3 inch 12 bolt housing? Any info would be appreciated.
Dudler is offline   Reply With Quote
Old 03-11-2015, 12:02 AM   #16
Captainfab
60-66 Nut
I don't think you should have any problems. With installing a 10.5" 14 bolt, most guys will grind a small notch in the axle tube for clearance for the U-bolts. The 14 bolt has 3.375 diameter axle tubes. You could use the 14 bolt trailing arm mounts that I make for that 9" housing.
Old 03-11-2015, 01:57 AM   #17
RustyBucket
RustyBucket's Avatar
While your working you might consider a disc. conversion like the inexpensive one I recently installed on the 9" ford in my Nova. Cheap kit included calipers, rotors, brackets, hoses, & hardware for less than $300 free shipping from Summit. Uses little 11' o.e.m. rotors & calipers from the front of some little GM product. They seemed to have a variety of kits and were pretty helpful. It all bolted together and works GOOD. I got the tech. info and part number from Right Stuff Detailing but bought it from Summit a little cheaper AND with free shipping.
www.getdiscbrakes.com/
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 03-11-2015, 02:39 PM   #18
RustyBucket
[quote=RustyBucket;7085123]
"your" -- YOU'RE
/quote]
I HATE it when I misspell stuff at 2 AM and see it the next afternoon.
Current toy trucks:
Old 03-12-2015, 08:52 PM   #19
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: 9 inch conversion question??
Thanks dinnut!
I got some for sale Bud!
http://charlotte.craigslist.org/pts/4833780025.html
Ford 9" Rear Axle Information
http://67-72chevytrucks.com/vboard/s...d.php?t=358081
Ford 9-inch Rear End Length Data
http://67-72chevytrucks.com/vboard/s...d.php?t=354261
Everything you've ever wanted to know about Ford 9 Inch Differentials!
http://67-72chevytrucks.com/vboard/s...d.php?t=454229
Ford 9" Rear End's out of a 1957-1959 Ranchero and station wagon's are 57.25 inches (narrowest 9" housing)
http://67-72chevytrucks.com/vboard/s...d.php?t=662341
Online engine resources (casting numbers, calculators, etc.)
http://67-72chevytrucks.com/vboard/s...d.php?t=382583
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-12-2015, 10:58 PM   #20
Dudler
Hey Rusty
I'm already there when it comes to brakes, I'm slowly buying parts and ended up buying a full chassis out of a 74. It had a 700hp BBC with tranny and rear end built to handle the power. So now in the process of crossing everything over to my truck. I had the CPP big brake kit before so just needed the bracket so I can mount the rear 12" discs out back on the 9 inch. Cant wait to get rid of all drum brakes on all 4 corners gone. Should be able to hit the corners with more speed now I'm going to end up with a pile of high performance parts of the 74 that wont transfer over but the price was right.
Don't worry about the grammar I wouldn't have held that against you lol!!
Old 03-12-2015, 11:07 PM   #21
Dudler
Hey Bad62,
I actually have a spooled 4.56 for sale as well. I'm buying a Trac-loc 3.50 3rd member that is rebuilt for $300 so I can at least drive it a 60mph with my TH400 below 2500 rpm. I've got to tune down my motor to make it more streetable so I can at least drive it not trailer it to some events
