08-23-2014, 09:08 PM | #1 |
New to me axles, what to watch for?
Well i finally picked up a set of 3/4 ton axles for my 74 Chevy project. It is a dana 44 and 14 bolt with 4.10 gears. Axles are not my strong point, so hoping you all can help. For 175 bucks figured what the hell i can't go wrong. What should i look for when i tear into em to freshen em up? He said they been sittin for a while, so unsure as what to look for... Thanks for the help in advance ya'll. one thing to add, is i will be getting rid of my rear brakes, so what can go and stay?
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
08-23-2014, 11:52 PM | #2 | |
60-66 Nut
Re: New to me axles, what to watch for?
How far are you going to go to 'freshen em up'? Are you going to install new bearings and seals? The first thing to look for is excessive gear backlash. Also on the front diff, look at the axle u-joints and see how they look. You're not going to run rear brakes at all? That's not a good idea.
08-24-2014, 04:02 PM | #3 | |
Bolts are STRONG, but no clue how to go through it, is there a book or 2 on these axles?
08-24-2014, 04:11 PM | #4 |
Add a pic
09-15-2014, 10:38 PM | #5 |
Update!!! I found a guide!!!
http://www.pirate4x4.com/tech/billav...4b_Gear_Setup/ This week since it's only 5-8's i'ma start the teardown!!! YEEHAW!
10-03-2014, 06:25 PM | #6 |
Well the rust is too bad on the inside, it mixed with the gear oil n is inside the posi and bearings n everything. Gonna have to do a full on rebuild but hey, at least i won't have to worry about it afterward. Is the a guide on a full blown rebuild?
Tags |
axles, dana 44, rebuild dana 44 |
