09-16-2014, 11:46 AM | #1 |
Doug Thorley header?
Does anyone happen to know at what angle the flange from the collector is at in relation to the frame? I have the 1 7/8" headers. I'm at work and away from home for several weeks and wanting to order some pre-bent exhaust piping so I can get my exhaust done next time I'm home. My goal is to keep the exhaust tucked up inside the frame rail for clearance reasons since my truck is low. Thanks in advance.
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435 |
09-16-2014, 01:47 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Doug Thorley header?
I believe the headers will dip below the frame rail by a tad, maybe an inch I believe.
OK, I lied. here is a post... http://67-72chevytrucks.com/vboard/s...d.php?t=287231
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-16-2014, 06:38 PM | #3 |
I had seen that thread before but it only talks about the dt's with 1 5/8" primaries. Mine are the 323c-y with 1 7/8" primaries
09-17-2014, 08:56 AM | #4 |
have you contacted the rep with DT?
09-17-2014, 12:33 PM | #5 |
I don't know the exact angle, it's pretty tight, but you can keep the exhaust above the frame rails.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-17-2014, 01:01 PM | #6 |
No I haven't. I think it may be best to have some patience (which isn't my strong suit ) and wait until I get home and put a angle finder on it.
I was hoping you'd see this thread. Thanks for the pictures. Any pics of the back half? Did you do 2 1/2 true duals, x-pipe or h-pipe?
09-17-2014, 01:40 PM | #7 | |
09-17-2014, 02:18 PM | #8 |
Awesome! Thanks for the pictures
09-18-2014, 01:31 PM | #9 |
Off subject, but I need a driveshaft like that. Did they make that custom for you based on their Camaro DS? I too have a 2014 L99/6L80E and converting to LS3 but haven't figured out how to attach a DS yet.
09-18-2014, 02:31 PM | #10 |
Your welcome.
I had the Drive Shaft Shop build it for me.
09-18-2014, 05:24 PM | #11 |
Thanks man!! I'll call them when I have some measurements..
09-18-2014, 05:52 PM | #12 |
Frank is who I spoke to. I would call him before I measure.
