Old 10-05-2014, 08:38 PM   #1
MattPSU
MattPSU's Avatar
5.3L with AC compressor in stock location?
I picked up on Friday an L59 5.3L out of a 2005 Avalanche that I'm going to swap into my 1972 C10. I have a bunch of stuff worked out but I'm looking for a set of motor mounts that will allow me to run the stock 5.3L AC compressor if possible. I wasn't expected to get it as part of the deal with the engine & transmission, but since they included it, I'd like to use it if I can. Any input, suggestions, feedback would be greatly appreciated.
Thanks - Matt
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 10-05-2014, 10:43 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 5.3L with AC compressor in stock location?
The ECE conversion mounts will allow you to run the ac in the stock location.
Hart_Rod is offline   Reply With Quote
Old 10-06-2014, 09:45 AM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
The dirty dingo sliders will also allow the compressor to mount in the stock location if you get creative.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-06-2014, 10:03 AM   #4
Hart_Rod
Hart_Rod's Avatar
LoL, true
Old 10-06-2014, 10:26 AM   #5
Low Elco
Made my own- took a day, solved all problems. Look on my Ol yeller's new heart thread and this one (Where I got the idea)
http://ls1tech.com/forums/conversion...71-c-10-a.html
Big tube out the top- cut it and turn as necessary, reweld. Small tube- there's a fitting in the condenser on mid-'00's Tahoes that takes it straight out the front. Chop the appropriate turned fitting off somethin else to hook it over the frame rail, weld, good to go!
Low Elco is offline   Reply With Quote
Old 10-06-2014, 09:04 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: 5.3L with AC compressor in stock location?
Matt for the hasle of fittings and hooking up the lines it's well worth it to have it mounted up on top. + if you ever have to work on it are swap out the compressor you want have to pull the motor to do so. My 2 cents worth. Plus it will look as though it period correct up top.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-07-2014, 05:01 AM   #7
chuckmc8
It's alsways something.....
chuckmc8's Avatar
I used the factory 5.3 compressor and also the factory evaporator from a 71 and it works fine. BUT it was a major PIA. In my case I can change the compressor by removing the radiator and shroud and pulling out the compressor thru the front. Just depends on your budget and time and what you want to do. It can be done but I prolly won't do it again :-)
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 10-07-2014, 08:29 AM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have the POL mounts and non adjustable plates. I also have my compressor mounted low and have the DOCs Blocks, I had to massage the frame rail to allow me to access the compressor bolts and fittings when servicing.
Hope this helps.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-07-2014, 08:40 AM   #9
faribran
Clyde, are the DOCS blocks still available ?
faribran is offline   Reply With Quote
Old 10-07-2014, 11:51 AM   #10
Mayfield
http://coldhose.com/specialty-fittin...-adapters.html
This is where I got mine. Scroll down to the bottom.
I used hedman LS swap kit, it uses the compressor in the stock location.
Mayfield is offline   Reply With Quote
Old 10-07-2014, 02:56 PM   #11
Clyde65
Clyde65's Avatar
NOT UNDER "DOCS" But like Mayfield said, there are some good choices out there. I think there was another one also....
Clyde65
Rebuild of Clyde
support our troops!
Old 10-07-2014, 06:58 PM   #12
faribran
Mayfield, Clyde, thanks guys
