Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-08-2014, 02:50 PM   #1
Robznob11
Robznob11's Avatar
just some ideas
It's probably Ben done but I was thinking . Why not take a long bed frame cut off 6" on the rear and install a short bed. Then mount the cab back 12" and extend the fenders and hood 12" to match. Better weight ratio and funny car look. Or you could extend the cab 12".and make the doors longer. Wonder what it would look like.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-08-2014, 07:29 PM   #2
cableguy0
Re: just some ideas
Its entirely too much work for little benefit. You can always cut the firewall and slide the engine back. Adding another foot to the front wont help much. The only real benefit is moving the engine itself back and closer to the rear for better weight transfer. A shortbed frame accomplishes the same thing without the ridiculous amounts of work.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-08-2014, 08:28 PM   #3
Robznob11
Robznob11's Avatar
Re: just some ideas
Well that's what I ment after scooting the cab back scoot the engine back as well I have mineback 2.5 # and custom suspension set up and can still blow the drag radials off with 440 up
LED TAILS
Old 10-08-2014, 09:09 PM   #4
cableguy0
Re: just some ideas
There are guys going well into the 9's with the stock truck arm setup. Proper springs and shocks make all the difference in the world.
Old 10-11-2014, 01:02 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: just some ideas
rob my engine and setup are pretty similar to what I see in your sig, just in a year earlier body. My engine is actually about 1" forward, and with my 325/50/15 m/t's and a stock truck arm setup, I have a very difficult time breaking the wheels free.
The biggest difference I see is that a) I have steel wheels which help with traction but suck with rotating mass and b) I have 3:73's instead of 4:10's.
Just thought it was interesting.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-11-2014, 10:07 PM   #6
Super73
Super73's Avatar
Re: just some ideas
Suspension, suspension, suspension.
I see you have a 4/6 drop.. How is this done?
What shocks do you have?
I have a 315/60/15 MT DR and it dead hooks my 418ci LS3 that makes 520rwhp with a 4,600 verter, 4.56's.. I am expecting to see some 1.3x 60's on the bottle next time out by simply tightening my front shocks..
2 clicks from full loose spun and went 1.57 on the bottle
4 clicks from full loose spuns less and went 1.43 on the bottle
I am thinking 2-3 from full tight (6-7 from full loose) should hold the 100 hit. Might need to go full tight for the 175..
My point is, don't blame the tire. If your suspension is too stiff and you don't have a shock to control it, you will not get it to work with pretty much any tire.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 10-11-2014, 10:59 PM   #7
Robznob11
Robznob11's Avatar
Re: just some ideas
Lol. I did not throw these ideas out cause I had a problem. And when I said I could blow the tires off. It was a little stretched if they are hot they will hook fine. I probably should have put this on the suspension section. I was just thinking how well a truck could handle and hook if the engine were more centered. And how cool it would look if the fenders or cab were stretched. I mean the long frame is already stretched so the hard part is done. I just like seeing things out side the box. I'm not running fully adjustable shocks but I am running 2.5 spindles and the rest is springs and doshe tech drop shocks. And an antisquat kit with a 4* shim for the rear pinion . I know you can make these trucks hook good and in my opinion truck arms can't be beat. But if the engine was back more you would probably have a better all around truck assuming you four get equal weight on all 4 corners as opposed to the heavy nose of truck setup. In actuality I can light up the rears real good once then after I stop if I try to do it again I will easily push through the brakes. Sorry to toot y'alls horn just dreaming one day😁😝
LED TAILS
Old 10-11-2014, 11:38 PM   #8
Super73
Super73's Avatar
Re: just some ideas
Moving the battery from the front to the rear is said to be equal to moving the motor back 6"..
Old 10-12-2014, 07:36 PM   #9
tinydb84
tinydb84's Avatar
Re: just some ideas
Does it really? Damn, maybe I should add a second battery! lol
David
Instagram: myfabguy
Old 10-13-2014, 08:24 AM   #10
djracer
djracer's Avatar
Re: just some ideas
I hope to have my turd into the 7's with trailing Arms when she comes out of the paint shop!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
