Old 10-19-2014, 07:21 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
8" lift guys-steering question
So im looking at an 8" BDS kit for my 87 V30 crewcab, has the raised steering block and raised steering arm, according to Off Road Design, this system is junk and anything over 8" u should go to crossover steering, im not going rock crawling, maybe the odd mud bog, but mostly highway and gravel road driving. Just wondering if anyone with bigger lifts has had any steering issues doing it the old fashioned way?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 10-19-2014, 08:15 PM   #2
dieseldawg142
dieseldawg142's Avatar
Re: 8" lift guys-steering question
8" on my '85 crew. steering block, dropped drag link, dropped pitman arm. never had a single issue. had crossover on my 12" lift blaze, great off road, was not crazy about it on the street. mostly street, i'd go with the push-pull.
dieseldawg142 is offline   Reply With Quote
Old 10-19-2014, 08:26 PM   #3
1968vetL-71
Junior Member
1968vetL-71's Avatar
I can definitely speak from experience. I've had a bunch ( prob a dozen ) pickups, blazers and suburbans with 8"-12" lifts on them i installed. Before the crossover was really the thing too do, the tall block, raised arm, dropped pitman and nasty big ol S-drag link was all that was available. Steering was adequate and then their just wasn't much too compare it too. Parts wore out quick and kinda sucked.
I just installed a new 8" lift on my 91 crew cab and went with the ORD crossover steering with the Heavy Duty tierod. What a completely different experience. It doesn't have any big truck mannerisms at all. I would never go with any other steering correction other than crossover. Im sure it helps having EVERYTHING new or rebuilt up front including the D60. I'm sure some Naysayers will pop in and say blah blah blah.... but speaking from my own experience... NO COMPARISON!
I can honestly say with the New Toyos, its incredibly quiet and smooth. I kinda miss the roaring sound of a huge swamper and some big ol bouncies in action riding shotgun from the rough ride!! ahhhh the days!!!!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 10-19-2014, 10:46 PM   #4
72 Copper C-10
72 Copper C-10's Avatar
I totally agree!! My dad absolutely loves his ORD set up for his short bed with a 4 inch lift, he said anything else doesn't compare. It definitely made the truck more drive able. I'm doing crossover steering on my truck also with a 4 inch lift and I expect to work great!
72 Copper C-10 is offline   Reply With Quote
Old 10-20-2014, 08:34 PM   #5
ryanroo
ryanroo's Avatar
at that lift height i recommend you go crossover, but it may very well not feel as great as it could. when leaf springs get that much arch in them, they become a less effective control for the lateral movement of the axle. so when you apply steering input it will also push or pull the axle out of centerline of the chassis. you feel it as a sort of bump steer. the taller the spring, the worse the effect. that is why at those lift heights sometimes the push pull with a stack of corrections feels better. i think push pull is the better system if you can keep from stacking to many corrections. as it gets taller, the geometry that made it so effective with lower ride height goes away.
so my caveat for the recommendation of crossover is that you also go with a track bar. properly engineered to work with the crossover steering it will eliminate the wander from the spring flex and allow for true bump steer free crossover. it will also likely help the truck feel better on the road.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 10-21-2014, 03:22 AM   #6
andrewmp6
I'm with ryanroo and to get a track bar sky-manufacturing.com has one.
andrewmp6 is offline   Reply With Quote
Old 10-21-2014, 03:06 PM   #7
beardface
beardface's Avatar
As I was reading this I was thinking tall leaves with a track bar and crossover steering would prolly work pretty well. Then I get down here and Ryanroo had already said it.
Great minds think alike I guess
Leon
'68 K20 fleetside, 400sb/sm465/np205, 4" lift, 32" tires.
beardface is offline   Reply With Quote
Old 11-28-2014, 12:38 AM   #8
Blue85
Oilfield Trash
Blue85's Avatar
any of you guys that went with with crossover steering, were you able to keep your sway bar?
87 Chev 3+3 4x4
