Old 10-28-2014, 06:26 PM   #1
jack092060
46 Chevy truck
Hey I'm thinking of buying a 46 chevy truck. Was wondering how hard it is to change the 4 speed to automatic. And what kind of automatic will fit on 216 6 cylinder. Thanks
jack092060 is offline   Reply With Quote
Old 10-28-2014, 06:30 PM   #2
lowrodderchev
lowrodderchev's Avatar
Re: 46 Chevy truck
for the 216 you will need a adapter plate to use a automatic. I'm assuming your thinking a 350 tranny. the starter on the older 6 cylinders bolts to the fly wheel.
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 10-28-2014, 06:35 PM   #3
jack092060
Re: 46 Chevy truck
Thanks for info.
Old 10-28-2014, 06:39 PM   #4
NEWFISHER
NEWFISHER's Avatar
Re: 46 Chevy truck
Buffalo Enterprises in Arlington WA. for the adapter and stovebolt.com for a ton of info
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 10-28-2014, 07:14 PM   #5
lowrodderchev
Re: 46 Chevy truck
langdons stovebolt super nice guy sells the adapters last time I checked
Old 10-28-2014, 07:38 PM   #6
NEWFISHER
NEWFISHER's Avatar
Re: 46 Chevy truck
Something else to consider:
A 55 car or 53 up truck 235 is full pressure and a much better motor. A T5 5 speed will bolt right up using the existing bell housing/clutch with a jeep input shaft. I just did this on my 46 with a 235 in it.
A 250 will fit in the hole and you can bolt up a 700r4 to it. I did this on my 50
Both are great options for a driver rig and you loose the enemic 216
GOD BLESS AMERICA!
Old 10-29-2014, 06:32 AM   #7
47 Fasttoys
47 Fasttoys's Avatar
Re: 46 Chevy truck
OK, just to be a smart a$$ " the starter on the older 6 cylinders bolts to the fly wheel." Damn, someone must be running 42 miles of battery cable. So what exactly spins the flywheel? LOL I think I've had 1 to many TSINGTAO.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 10-29-2014, 07:41 AM   #8
lowrodderchev
Re: 46 Chevy truck
Rob
Funny guy I mean the bellhousing
Old 10-29-2014, 03:09 PM   #9
NEWFISHER
NEWFISHER's Avatar
Re: 46 Chevy truck
When using Buffalo or Tom from Stoveboltengine.com's adapter, the 216 starter is removed from the bell housing and will bolt to the adapter with supplied hardware.
GOD BLESS AMERICA!
