11-01-2014, 05:51 PM | #1 |
pinion/axle angle
Swapping in 3rd gen Camaro rear, the question is to get close to what I need for pinion angle - If I level the spring mounting pads how much angle should the pinion have?( as close as I can tell it s/b about 8-10 degrees ?)
Thanks 58 step side 350/350
http://67-72chevytrucks.com/vboard/s...d.php?t=481531 |
11-01-2014, 09:19 PM | #2 |
Re: pinion/axle angle
Here's a link on figuring out pinion angles.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf |
11-01-2014, 09:34 PM | #3 |
Normal engine tilt will be about 4 degrees down (with a level frame). If that's what you have, then match it with 4 degrees up at the pinion. So, check the engine first.
11-01-2014, 10:03 PM | #4 |
Hollister Road Co.
This may be helpful in determining your angles
http://www.tremec.com/menu.php?m=154 |
