11-06-2014, 11:54 AM | #1 |
El Rancho: 55 1st, S10 Frame, LS1, 4L60E
So here is the beginning of my journey... I've been working on the truck for about 2 years and am only now starting a build thread. I will catch things up in the next few days along with progress photos etc. I am doing this for multiple reasons, I believe it will help motivate me to keep going, I have a lot of questions and hopefully can get some answers, and I am sure others are doing the same and maybe it can help them too.
Here we go! |
11-06-2014, 12:56 PM | #2 |
A320 Pilot/USAF Retired
Re: El Rancho: 55 1st, S10 Frame, LS1, 4L60E
Sounds like a cool build, so let's see some pics ASAP!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
11-21-2014, 12:43 PM | #3 |
So here are some pictures to catch up a bit. Currently I have a 4" drop axle underneath the truck with 3" blocks in the rear. The original 235 6 cyl is still in the truck. The reason I chose to do the swap is because I want to drive this thing a whole lot more than I currently do. I want power brakes, power steering, the reliability of fuel injection and the power/ wow factor of the LS engine. I chose to go the s10 route because I also wanted to keep the truck running/rolling while I did a lot of this in fear that I would loose interest and would end up with a junkyard full of parts.
The truck as she sits now... The frame next to the truck just shortly after I picked it up.... The "rolling frame" headed to my house to get some work done... In my garage... The 5.3 power plant awaiting a 4L60E... I now pronounce them Mr. and Mrs.... Working on getting the engine and trans placed on the frame... Not mounted but just mocked up.. Motor mounts in the works... |
11-21-2014, 12:47 PM | #4 |
Now I know that this may not be the best way to work but I have seen quite a few projects with the s10 frame and the LS engine and I understand that clearance up front is super tight. I have looked at what everyone has done and I am planning on shifting the engine back a hair from any that I have seen. My thoughts are that it would be easy to cut and fab a recessed firewall but if there is not enough clearance up front... you are up a creek. I have ensured that the PS pump and PS box have clearance, the manifolds clear pretty well..
03-10-2015, 11:24 AM | #5 |
So I haven't posted in a while but I've been around. Just a bit of an update...
finally got the engine started for the first time. A bit rough, I had some exhaust leaks and vacuum leaks but it was a successful day. http://youtu.be/o0T7nx_A7R4 Here is one just a week later once all of the air was out of the lines etc. http://youtu.be/C2HLgiFoXOE |
