Old 11-07-2014, 12:31 PM   #1
b-mac
b-mac's Avatar
LS Truck Pan - Dry Sump Block? - Where to find?
5.3 LS with a truck oil pan on it. It appears the truck pan has outlets for a dry sump kit, or maybe a remote filter. I just need to block it off. I assume someone (GM) makes a kit.
I can't find any information on it. Do any of you guys know where to find this block, or have another idea for addressing the problem?
Thanks in advance.
b-mac is offline   Reply With Quote
Old 11-07-2014, 12:37 PM   #2
jackyl9999
jackyl9999's Avatar
Re: LS Truck Pan - Dry Sump Block? - Where to find?
It is for the oil cooler. You can buy block off plates on ebay
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 11-07-2014, 12:48 PM   #3
88Ironduke
Pretty certain it cannot be blocked off. It needs a run around plate bolted up.
88Ironduke
Edit just checked the block plates out there for sale and they are indeed run around plates. Looks solid but allows oil to flow from side to the other. Don't block it off totally.
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 11-07-2014, 01:00 PM   #4
jackyl9999
jackyl9999's Avatar
http://www.ebay.com/itm/OIL-PORT-ADA...42e3f0&vxp=mtr
1990 K1500 Daily
Old 11-07-2014, 01:13 PM   #5
b-mac
b-mac's Avatar
You guys rock. Thank you.
On a stock (for now) 5.3, do you think I need an oil cooler? I see guys running tranny coolers.
Old 11-07-2014, 01:16 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I dont have an oil cooler on mine. trans cooler yes!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-07-2014, 01:18 PM   #7
jackyl9999
jackyl9999's Avatar
I used a plate with 1/8 npt port for my oil pressure gauge.
1990 K1500 Daily
Old 11-08-2014, 10:07 PM   #8
BigDan3131
BigDan3131's Avatar
Good to know the ports are there and can be looped but I need to run a cooler after my turbo. How big are the ports?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 11-23-2014, 03:14 AM   #9
Gobuffalo
Gobuffalo's Avatar
Look at ICT Billet. They have all kinds of stuff for LS engines. I bought their oil cooler bypass plate, EGR block off and canister purge valve block off. Aluminum pieces with O-ring seals and stainless hardware.
Gobuffalo is offline   Reply With Quote
Old 11-23-2014, 03:15 AM   #10
Gobuffalo
Gobuffalo's Avatar
Egr
Old 11-23-2014, 03:17 AM   #11
Gobuffalo
Gobuffalo's Avatar
Purge valve
Old 11-23-2014, 02:17 PM   #12
H20cooled
Got the same ones they look great and do an excellent job.
H20cooled is offline   Reply With Quote
5.3, lsx, oil pan
