11-12-2014, 02:23 AM | #1 |
eaton HO brakes
My 69' C20 is in dire need of a rear brake job. It has an eaton ho52 with 11x2-3/4" brakes. Considering how difficult it is to locate usable drums, I started looking for a parts axle prior to tearing apart my rear axle assuming the drums were beyond spec. I located an eaton in pieces with 5.13s, a no-spin, and usable 12x2 drums. I have read through all the eaton threads I can find on this board, but have not seen mention of 12x2 brakes. What years and/or models did this size brake come on? Is the taller 12x2" or the wider 11x2-3/4" rated to stop more? Thanks in advance.
11-12-2014, 04:19 AM | #2 |
Carpe manana
Re: eaton HO brakes
Hello neighbor. I'm not sure if the difference reflects that between an HO52 vs an HO72, which I thought had larger brakes and was used for one ton (C30) applications. Would either of these NAPA drums work?:
http://www.napaonline.com/Catalog/Ca...203_0325237577 http://www.napaonline.com/Catalog/Ca...203_0325237577
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
11-12-2014, 08:16 AM | #3 |
Loves all GMC trucks
Re: eaton HO brakes
I know Vintage windmills deals with a lot of these axles... I would contact him for some advice too. He would be able to provide first hand experience and maybe some tips.
Mike If your helping someone and expecting something in return... your doing business not kindness! |
11-12-2014, 10:12 AM | #4 |
Re: eaton HO brakes
Centric 122.66024 drums will do the job.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
11-12-2014, 03:39 PM | #5 |
Re: eaton HO brakes
I appreciate the part numbers and will follow up. I am curious though - the first thing you read from just about everyone about the eaton rear is "parts are expensive, drums and R&P are hard to get - swap in a corporate 14b". The Centric 122.66024 seem widely available and are not too outrageous pricewise. What am I missing?
11-12-2014, 05:15 PM | #6 |
Re: eaton HO brakes
I believe there is a thread where it is said "they don't fit"
<- from a guy who, now, has a 14 bolt
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-12-2014, 06:42 PM | #7 |
Re: eaton HO brakes
Here's a good thread regarding the drums.
http://67-72chevytrucks.com/vboard/s...d.php?t=443837 |
11-13-2014, 11:01 PM | #8 |
Re: eaton HO brakes
I put 122.66024's on mine last April with no problems at all, everything fit as it should. The factory had an issue with the bolt hole size on this non-demountable type drum for a while but Centric fixed it.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 Last edited by bollybib; 11-14-2014 at 02:52 PM. |
Tags |
12x2, eaton |
