Old 11-25-2014, 12:22 PM   #1
underliner6
underliner6's Avatar
Replacement Body Bushings
I am in the process of replacing the body bushings on my 72. I have succesfully replaced all of the bushings except for the rear two by jacking up the body from the rockers.
What is the best place to jack up the rear to access the two bushings next to the gas tank? I'm worried that if I jack it from the bottom of the tailgate, even with a piece of 2x4 under it, it's going to put too much stress on the tailgate.
What my best option here?
Jim
Jim
1972 K20 Cheyenne- 350/350/205
1972 K20 Cheyenne - 350/SM465/205
underliner6 is offline   Reply With Quote
Old 11-25-2014, 01:56 PM   #2
TonyJohnson
TonyJohnson's Avatar
Re: Replacement Body Bushings
Good question. I'm getting ready to do mine and will listen, as well.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 11-25-2014, 02:00 PM   #3
skorpioskorpio
There is a heavy bolt on bed support, as long as you still have rear wells in place you should be fine with that one. When I stripped mine I used that support to hold up the body while I dropped the frame out from underneath.
skorpioskorpio is offline   Reply With Quote
Old 11-26-2014, 11:56 AM   #4
underliner6
I will take a look for this bed support your talking about. Thanks!
Jim
Old 11-27-2014, 12:57 AM   #5
Chulisohombre
Chulisohombre's Avatar
I used a scissor jack between the rear body and frame just in front of the gas tank.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 11-29-2014, 07:16 PM   #6
Moreyel
Active Member
Moreyel's Avatar
Are most of you using the neoprene or rubber?
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more.
Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3.
Next: Rust removal on my Blazer.
Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup.
Members Met: Aldtime, DeadheadNM
Moreyel is offline   Reply With Quote
Old 11-29-2014, 07:20 PM   #7
Chulisohombre
Polyurethane
Old 11-29-2014, 07:25 PM   #8
Moreyel
Active Member
Moreyel's Avatar
Yeah, that's what I meant. Thanks Chulisohombre
Old 11-29-2014, 07:26 PM   #9
Chulisohombre
No problem. Neoprene is to keep you warm. Lol
Old 11-30-2014, 02:51 AM   #10
underliner6
The mounts I put on are polyurethane. I never want to replace these again in my life time unless I do a frame off. I got mine from synergy suspension and its a nice kit.
Jim
Old 11-30-2014, 03:10 AM   #11
Moreyel
Active Member
Moreyel's Avatar
Wow. That's encouraging. I'm not doing a frame off!
Old 11-30-2014, 03:17 AM   #12
skorpioskorpio
Synergy or Energy?
Old 11-30-2014, 09:27 AM   #13
Chulisohombre
The poly will last forever so that's why I did mine that way as well. I also
Wanted a more solid feel to The truck. I won't ever be pulling these off again either if I can help it. Put in coated hardware so rust can't eat away the bolts through the sleeves in the body this time too. Was a pain to get out the originals. I'm pretty sure mine are energy suspension. I used them to replace my front shackle bushings as well.
Old 11-30-2014, 10:18 AM   #14
bumperjack
I have been planning to do this and I think I have two options that should work depending on equipment available.
1: Install eye bolts in the rear corners with a backing plate under for more strength, using a chain and a cherry picker lift the rear and support with stands. I am a little concerned the eye bolts will bend the bed when lifted even with the plates so either use a long piece of thick walled square tubing or if you plan on removing the bolts (I want to leave them in for tie downs) mount them in the center then fill holes when finished. Use jack stands to support the tub while replacing for safety!
2: Raise the rear and support the body only with tall jack stands, place them on the bed bracing or on something else structural (NOT the tailgate or bedside sheet metal), lowering the vehicle onto another set of stands should allow you to remove the jack to replace the bushings safely.
bumperjack is offline   Reply With Quote
Old 11-30-2014, 10:51 AM   #15
underliner6
Synergy or Energy?
Correction: energy suspension
Jim
Old 11-30-2014, 12:05 PM   #16
Senorx
Senorx's Avatar
I also ordered the Energy Suspension kit. Hopefully be tackling this job in a couple of weeks.
Senorx is offline   Reply With Quote
Old 11-30-2014, 12:36 PM   #17
Chulisohombre
I Just used a scissor jack Between The body and frame and replaced them one at a time. The front ones under the radiator support were the hardest. Had to pull the front clip and lift the support to get those bushings. Had to use a couple lift straps and a two by four to hold it up to get it apart. Also in the rear four bolts they are spot welded to the body so have to be grinded off and I just used a sawzall to get the nuts off of they break. Then had to use a air chisel and sledge to pop them back Through the body since they are usually rusted together.
Old 11-30-2014, 12:59 PM   #18
Senorx
Senorx's Avatar
Can u post a pic of the scissor jack you used?
Did everybody install the bushings with the top on or off?
Old 11-30-2014, 02:49 PM   #19
Chulisohombre
I used just the regular type of jack that every car has in the trunk to change a tire. The body only has to be lifted Off enough to get the old ones out and install the new bushings. Most kits come with new bolts but I used the original ones for the bushings under the front floorboards as the stock ones were much bigger and stronger than what Was in the kit. But the rest of them I used as they were coated for rust protection. I did one at a time just moving down from front to back. All have to Be loosened up first as well but I didn't have much left of my bushings so that didn't really Matter. The back four were the second worst because of the taipan, bumper, and gas tank. Plus just the years of rust had corroded everything. There was no rubber left at all on the tailgate far rear ones so my trucks body was flipping around when I took corners sharply. Kinda scary.
Old 11-30-2014, 03:01 PM   #20
Senorx
Senorx's Avatar
I'm just buying all new bolts. I guess I'm expecting the worst and having to cut my bolts off due to rust. My Energy Suspension didn't come with the bolts. Anybody have a source for the bolts?
Old 11-30-2014, 03:03 PM   #21
TonyJohnson
You can use the parts list and pics in the LMC catalog to get sizes, then just source at a hardware store. Make sure you get the right grade...
Tony Johnson
Old 11-30-2014, 03:19 PM   #22
Senorx
Senorx's Avatar
What's the usual grade and what is overkill grade bolts?
Old 11-30-2014, 04:10 PM   #23
underliner6
I kept my top on for the process. Even with the top in, my door alignment is now off and my doors don't like to close easily. The fun of the job!
Jim
Old 11-30-2014, 04:19 PM   #24
Senorx
Senorx's Avatar
That's what scares me. My doors close great and are aligned.
Old 11-30-2014, 04:33 PM   #25
skorpioskorpio
Bear in mind the original bolts are tack welded in.
body bushings, body mounts
