Old 11-26-2014, 08:23 PM   #1
Vanhalen1985
Isolating noise when in 4wd. 72K10 Help please
Running a NP205
When I put the truck in 4 I have this clanking noise coming from under the cab. It doesn't happen when in 2wd with the hubs locked or while in 4wd with the hubs unlocked. Only when in 4wd with hubs locked. I originally thought the drive shaft knuckle was hitting the exhaust but I ruled that out. With further investigation i discovered that the the housing coming out of the TC connecting to the front drive shaft was loose. It appears that when engaged the play is creating the noise from having to much "wobble."
Would this be a bad bearing? Does this even make sense that it only does it when hubs are locked and in 4wd? Any input is GREATLY appreciated!
Vanhalen1985 is offline   Reply With Quote
Old 11-27-2014, 11:18 AM   #2
RANDY COX
RANDY COX's Avatar
Re: Isolating noise when in 4wd. 72K10 Help please
I think you answered your own question...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-01-2014, 09:58 PM   #3
72_K10_Vegas
72_K10_Vegas's Avatar
Ditto, you gotta have some fluids in the wrong area, that would splain things as well
72 K10
72_K10_Vegas is offline   Reply With Quote
Old 12-02-2014, 08:26 PM   #4
Vanhalen1985
Well fellers I discovered the root cause of the noise. I'm embarrassed by it but oh well. When I bought my new be Goodrich all terrain tires I went a size smaller in the front than in the back. It never even occurred to me that this would throw off my diffrential ratio and cause things to bind. Luckily no damage done except that to my pride.
