12-24-2014, 03:14 PM | #1 |
Rear Axle Questions
I am working in refurbishing my '72 K10 and I am in need of some help with identifying my rear axle. The only numbers I can find are the ones pictured. It looks like it is obviously not the original axles since spring perches have been moved. Also wondering if the u bolt setup is right. I just ordered a skyjacker 2.5" soft ride. If not what would I need to correct and will I have any other issues with staying with this axle setup.
Thanks Nathan
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
12-24-2014, 05:32 PM | #2 |
Re: Rear Axle Questions
Pretty standard Chevy 12 bolt.
12-24-2014, 09:47 PM | #3 |
Minnesota sure takes its toll on steel doesn't it
12-24-2014, 11:19 PM | #4 |
Depends on where you are in Minnesota. But yes we have rust.
12-25-2014, 01:52 AM | #5 |
Yeah its a 12 bolt if you ever need help iding a axle http://coloradok5.com/axleguide.shtml
12-25-2014, 01:33 PM | #6 |
I know it is a GM 12 bolt looking for answers on specifics. As stated above. By looking through threads the axle seems to be modify correctly.
Thanks Nathan
12-26-2014, 12:39 AM | #7 |
Look on top of the passenger side axle tube for a stamping code.
