1967 C-10 Build
Ive been working on my 67 C-10 for a few months now. The truck has a 454/th400 combo. Ive converted the truck to 5 lug all the way around.It has full Porterbuilt front and rear extreme drop members,control arms,trailing arms,transmission crossmember,trailing arm crossmember the bolt on body drop kit and the firewall shaving kit that they offer.
Re: 1967 C-10 Build
![]() Join Date: Apr 2010
Re: 1967 C-10 Build
This is going to be awesome! Almost hate to put sheet metal over that work of art. I'll be following
Wade |
Re: 1967 C-10 Build
Yeah the quality of all the porter built stuff is great. After seeing the frame put back together after powder coating I hate putting the body back on it as well. I shaved most of the firewall. As of right now it is just the brake booster,steering column, and wiring harness left on the firewall. Still deciding on if I wanna go with a under dash mounted brake booster.
Re: 1967 C-10 Build
After I was able to get the body on I found out the th400 did not want to fit through the factory opening and under the high hump transmission cover so I had to cut and extend the high hump transmission cover about a 1.5" taller and cut some more of the floor out for the yolk to clear and the body to sit down on the body mounts. I will be keeping the 1 piece driveshaft so I will have to tunnel my floor.
Grand PooBaa Member
Re: 1967 C-10 Build
That frame looks awesome. Did the Rack and Pinion come with the PB kit?
Re: 1967 C-10 Build
Yeah the rack and pinion came with the kit. I had to trim about a inch on both sides to be able to toe the wheels in.
Re: 1967 C-10 Build
Looking good
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
Re: 1967 C-10 Build
Re: 1967 C-10 Build
Chassis looks great!
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
Re: 1967 C-10 Build
Re: 1967 C-10 Build
awesome bro!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#13 |
Re: 1967 C-10 Build
Love the overhead shot. Trucks coming along nicely.
#14 |
Re: 1967 C-10 Build
Thanks i appreciate it. Just waiting on my wheels and tires to come in should be here any time...
#15 |
Re: 1967 C-10 Build
I'm in. Are you going to run a cowl hood? Looks like the air cleaner sticks out above the hood line when aired out.
#16 |
![]() Join Date: Nov 2010
Re: 1967 C-10 Build
#17 |
Re: 1967 C-10 Build
What size wheels are you getting?
#18 |
Re: 1967 C-10 Build
I'm going to have to change out the intake to a lower rise, and change out the tall air filter as well. I wanna keep the factory hood. I will be going with the Raceline hooligans in a 24x10's for the rears and a 22x8.5's for the fronts.
#19 |
Re: 1967 C-10 Build
Awesome build so far. I've got a lot of the same parts for mine but I'm WAY behind you on progress. I'll be following along for this one.
#20 |
![]() Join Date: Apr 2014
Re: 1967 C-10 Build
Very nice, keep the pics coming!
'70 2wd swb, 406 sbc, air ride and a big smile on my face! |
#21 |
Re: 1967 C-10 Build
I got my wheels in for the truck. There Raceline Hooligans 24x10 5.5bs on the rears and 22x8.5 with a 5.5bs up front. The tires are Nitto 420s 285/30/24 and 265/35/22. The front tires I will have to go with a smaller size due to them hitting the hood when layed out. Most likely will go with a 255/30/22. I ended up getting new bumpers,grille trim, and headlight bezels and took it out to Lonestar Throwdown in Conroe,Tx.
#22 |
Re: 1967 C-10 Build
And I ended up pulling the truck back apart after the show so I can go ahead and install the new one piece trailing arm cross member from Porterbuilt and get ready to install my motor,transmission, and drive shaft. And while its back apart I'm going to go ahead and take some more stuff to powder coating and run my brake lines and install the Porterbuilt tank and compressor mounts.
#23 |
Re: 1967 C-10 Build
nice
#24 |
Re: 1967 C-10 Build
The 1 piece trailing arm from Porterbuilt finally came in. I was able to install my drive shaft and transmission, and start on my driveshaft tunnel and raising the rest of the floor for the trailing arm crossmember.
1967 Body Dropped C-10
454 Big Block/TH400 Porterbuilt Extreme Front & Rear Dropmembers 22/24 Raceline Hooligans |
#25 |
Re: 1967 C-10 Build
That's a very impressive build. The workmanship looks top notch and I really like the color.
