Old 12-26-2014, 02:30 PM   #1
Bclanton
Bclanton's Avatar
88 K5 Blazer 4x4 wheels/lift
Hey guys, I have a buddy that has a 88 K5 Blazer 4x4 and he wants to do a 6in lift with 37s what would be a good wheel backspacing to use? Thanks for the help
Bclanton is offline   Reply With Quote
Old 01-02-2015, 12:38 AM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: 88 K5 Blazer 4x4 wheels/lift
What size wheels is he running? Also is he planning on trimming his fenders? 37" will rub the fenders with 6" lift.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-02-2015, 07:37 AM   #3
andrewmp6
How will he use the k5 also?37s on the stock axles rock crawling things are gonna break.If its more a mud truck/ daily driver they should be ok.And he should re gear the axles to match the tires.
andrewmp6 is offline   Reply With Quote
Old 01-02-2015, 11:57 AM   #4
Bclanton
Bclanton's Avatar
He wants to run 18s on it.
Old 01-02-2015, 11:59 AM   #5
Bclanton
Bclanton's Avatar
He's mainly going to be using it as a daily but mudding as well. What gearing should he use to match with the 37s?
Old 01-02-2015, 01:38 PM   #6
Chevy1TonFun
Grease Monkey
18" wheels should clear the brakes. So he can run what ever back spacing he wants. It all comes down to looks at that point. He knows with 37s he should expect to break stuff often. 1/2 axles handle up to 35" tires.
Old 01-02-2015, 08:47 PM   #7
I don't know. Of all the wheels I've put on all my trucks, I have no idea what the backspacing was. I've never had backspacing brought up when buying wheels. I think it's usually around 4".
Old 01-03-2015, 03:49 AM   #8
andrewmp6
A gear ratio chart http://www.alloyusa.com/gear-ratio-calculator/
