01-05-2015, 11:21 PM | #1 |
Any brake experts? I have questions...
I've owned half a dozen or so 1974 thru 1979 Chevy/GMC 4x4 pickups and none of them had good brakes. I put NEW not rebuilt master cylinders on them and they all act the same way.
When I'm driving and have to hit the brakes like in an emergency situation they never lock up. The pedal is hard, not spongy, but the brakes just do not work great. I've put brakes on lots of other rigs and they work great. I've been working on rigs for over 30 years, not that that makes me any kind of expert. My daughters 1990 Toyota 4Runner has excellent brakes. If I have to really hit the brakes when I'm driving it, it stops right now. The Chevys always are slow to stop and never lock up. What gives? I had Les Schwab (local tire store chain) put a NEW master cylinder on a 1979 K-20 and it still had weak brakes. The "pro" at Schwab said these trucks are just like that. Would a bigger bore master cylinder off a later model help? I've noticed that sometimes when the engine isn't completely warmed up and the choke is still causing the engine to high idle that the brakes are more sensitive and sometimes the rears will lock and slide. New booster maybe? Goofy proportioning valve? Thanks! |
01-06-2015, 12:28 AM | #2 |
Re: Any brake experts? I have questions...
My 85 K30 has hydro-boost and it will throw you through the windshield if you want it to. All my 97-2000 with hydro- boost trucks were like you just described. Difference was the anti lock braking they put into these trucks. I once had a 97 dully, brand new and if you came up to a stop sign/light aggressively, like I always do, and there was a slight bump in the pavement in the stretch you had your foot in the brake, it would go into anti-lock and you prayed no one was in front of you, well one time there was and I ended up rear ending the lady. Of course I always tell myself since then, to slowdown ahead of stops. I have always felt like you do, if I jam my foot down, brakes should lock-up. I'm sure the safety is well designed by the expert for anti lock though. Something you could try would be an adjustable proportioning block, and or braided steel brake hoses. Maybe one of the fellas here can tell you how to get more vacuum to your booster as well.
01-06-2015, 05:34 AM | #3 |
Low vacuum signal to the booster will cause what you describe. Also a smaller diameter master cylinder will improve mechanical advantage. Hydrobooster will also solve the problem.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
01-06-2015, 01:10 PM | #4 |
also the bigger the tire is, the harder it is to stop rotating.
1961 chevy K10 my build is------------61K10 build |
01-06-2015, 01:17 PM | #5 | |
If it is the latter, then the condition you are referring to is called "dashpotting" and is a characteristic of the vacuum booster. There were several engineering projects done over the years but none of them were successful in completely eliminating that effect. You won't be able to get rid of that without going to hydroboost. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-06-2015, 01:22 PM | #6 | |
A trained driver will almost always be able to beat the ABS for stopping distance. K
01-06-2015, 02:28 PM | #7 |
[QUOTE=Keith Seymore;6987959]Just to make sure I understand the complaint: when you make these emergency stops is it (a) a hard, linear application of the brake pedal, or (b) a really rapid whack of your foot on the brake pedal?
(b) A really rapid whack. |
01-06-2015, 04:58 PM | #8 |
Roger that.
No fix other than going to hydroboost (or manual brakes). K PS: 5000th post!
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-06-2015 at 05:03 PM. |
01-06-2015, 05:52 PM | #9 |
sorry to hijack but I have a HB setup in a C30 that works great but I feel a pulsing in the pedal when applied, is the pump or the box the culprit?
01-06-2015, 06:16 PM | #10 |
01-06-2015, 07:18 PM | #11 |
It pulses standing still
01-07-2015, 04:00 PM | #12 |
Sounds like the pump.
Other than hydroboost you can also do the 1 ton booster swap. Do a search there's a nice write up with pics. |
01-07-2015, 04:27 PM | #13 |
My experience. I have a 74 drive train under my 59. 74 K20 MC, 8" hot rod booster, 74 proportioning valve. During my two trial runs when I hit the brakes it would stop right now and toss me thru the windshield. 18# vacuum. Before this build I ran the same MC without the booster for 15 years and never had a situation, panic stop on asphalt or holding, long down slopes off road, when the brakes seemed to not work.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
01-08-2015, 12:44 PM | #14 | |
Back to the OP's complaint, I don't think it's fair comparing the brakes off a Taco to his truck. The Taco brakes were over built with fixed multi piston calipers and oversized rotors. People swap those brakes onto other vehicles including Z car nissans
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
01-08-2015, 06:27 PM | #15 |
That '85 K30's brakes aren't anything like the K20's.
I have K2500 Suburban brakes on my Jimmy from an '86, and even with 35" tires it stops great. I have the original power booster from the half ton brakes and a half ton master.
