Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-07-2015, 07:54 PM   #1
Daman
Drive shaft
What's everyone using for drive shafts?
My Boss' pickup has a 468ci BB, th400, tranny brake and runs high 11s low 12s. He cannot keep a rear driveshaft in it. He actually spun the pumpkin in the axle tubes a couple years ago.
His last one was supposed to be built to last but didn't
This was his last race
This was after our car show a couple years ago
Daman is offline   Reply With Quote
Old 01-10-2015, 07:27 AM   #2
Daman
Re: Drive shaft
So no one on here actually races their pickups or they just don't make any kind of power to break a stock drive shaft.
Old 01-10-2015, 09:49 AM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Drive shaft
I think the thing is, I don't know anyone that would try to use a stock driveshaft with any kind of power at all. Anything on slicks pulling 1.7ish 60' times should have good driveshaft with 1350 U-joints and better yokes.
I use 2 companies. Down to the 11's and 12's a good mild steel or Chrome Moly shaft with 1350 yokes and u-joints from Dynotec
Once a car (or ESPECIALLY a HEAVY truck) dips into the mid 10's or below, or 1.4 sixty's there is only ONE source for driveshaft IMO ,,, Mark Williams.
(Welding the axle tubes for anything that hooks should be SOP for anything that quick IMO)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-10-2015, 10:23 AM   #4
Lee H
Lee H's Avatar
Re: Drive shaft
I got my drive shaft from Inland Empire Driveline. Built to x HP and torque. You name x and they build it. Most any driveline shop can do this for street strip builds.
My C10 runs inconsistent low 13s to high 12s. Next up, a set of drag radials..........
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-16-2015, 03:16 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Drive shaft
3.5" .083 dom tube with 1350 Spicer u joints. 12.0xx
1.66/69 60' so far 100 + passes 4000lbs
http://www.drive-lines.com from the fresno store
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is online now   Reply With Quote
Old 01-16-2015, 10:00 AM   #6
Keith Seymore
Keith Seymore's Avatar
Re: Drive shaft
I'm low tens in a 3950 lb Chevelle (9.85 @136mph best), so around 900 HP. 555 cu in naturally aspirated, TH400 trans.
Dynotech 3" mild steel shaft, 1350 joints and yokes, no issues - probably 500 passes or so.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-16-2015, 10:54 AM   #7
vin63
It's Better With Nitro
vin63's Avatar
Re: Drive shaft
He'll need to talk with a reputable driveshaft maker about the specifications of the truck: weight, drive train (including driveshaft angles) and driveshaft measurements. There are some critical speed factors involved that are closely tied to driveshaft length. I have run everything from carbon fiber to sold steel from Mark Williams in my race cars. I have used local builders for my street car/hot rod projects. If he has exhausted the local builders, I would talk to Mark Williams, Strange, Denny's, etc. about building a driveshaft specific for his application.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-16-2015, 11:36 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Drive shaft
If I'm seeing the pic right. It looks like a long bed. Would make it a 2 piece ?
Old 01-17-2015, 08:30 AM   #9
Daman
Re: Drive shaft
Thanks guys. The last one that broke was built for that pickup.
Yes, it's a 2 piece. I forwarded him this info
Old 03-22-2015, 11:56 PM   #10
Hollow65
Hollow65's Avatar
Re: Drive shaft
Any update on this? I just had a dream I left licorice shaped driveshafts down Barona. I've been running a 2 piece for ever, but never had any traction. Kinda worried.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 03-25-2015, 08:53 PM   #11
ItsRandy
ItsRandy's Avatar
Re: Drive shaft
Inland Empire Driveline is where I got mine too. They don't give 'em away but nice parts.
ItsRandy is offline   Reply With Quote
Old 03-25-2015, 09:06 PM   #12
Hollow65
Hollow65's Avatar
Re: Drive shaft
Did you have to measure for them or did they have direct fit parts?
Old 03-26-2015, 12:55 AM   #13
Captainfab
60-66 Nut
Re: Drive shaft
I always recommend measuring your particular vehicle's driveshaft(s) length requirement. That is the only way to get a proper fit. There are just to many variables, particularly in a 50 year old truck, with the engine in either of 2 locations and any number of transmissions.
Old 03-26-2015, 10:45 AM   #14
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Drive shaft
Dynotech Engineering.
Great guys to talk with, super fast turnaround time, HIGH quality product.
http://www.dynotechengineering.com/
I got a 4" aluminum with 1350 joints. They rate it to like 1200 hp.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-26-2015, 07:58 PM   #15
Hollow65
Hollow65's Avatar
Re: Drive shaft
Thanks guys, I think I'm going with inland empire driveline.
