Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 01-11-2015, 08:19 PM   #1
E911manager
1946 Superior Bus 1 ton frame swap??
Anyone have any suggestions for a frame swap for a 1946 chevrolet 1 ton? The front end is what I am interested in. I picked up a 1946 superior bus today and plan on doing a late model chassis. Any of these on this site that I can get some info from?
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline   Reply With Quote
Old 01-12-2015, 07:38 PM   #2
wahl4m
Re: 1946 Superior Bus 1 ton frame swap??
i got a 39 international w/ a wayne body ,i used a chevy p-30 chassis, was a flat frame truck with a van body on it . some people use a say 74 about any motor home,tool truck,food truck can be used ? just try to match up the wheel base lengths to match your school bus,also watch that the front suspension is not too wide ! mine was the correct wheelbase and suspension width, but looks like the motor will need to be moved rearward!,the 2 front body mounts lined up w/ "waynes factory mounts ,the rears will need to be fabricated !if you watch the local parts peddlers, neighborhood newspapers a complete truck will sometimes pop up cheap ?
wahl4m is offline   Reply With Quote
Old 01-12-2015, 07:45 PM   #3
E911manager
Does the p30 have a straight front axle or a-arm? Also do you know how it is titled? The only numbers I can find on it are from Superior Coach Corporation.
Old 01-13-2015, 09:13 AM   #4
63 & 64 Bowties
and a few others
So, you're not gonna keep it as a bus?
I have a 39 1.5T that I've kinda put on the back-burner. I thought about maybe one day putting it on a 4x4 frame. With big mud tires it seems to fill the wide big-truck fenders.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-13-2015, 07:48 PM   #5
E911manager
Yes for sure keeping it a bus. Wife wanted a SUV.. So i got her one...
Old 02-28-2015, 03:56 AM   #6
NEWFISHER
NEWFISHER's Avatar
Pics or it hasnt happened
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 02-28-2015, 11:30 AM   #7
flashed
Im in for pics ,PLEASE ?
flashed is offline   Reply With Quote
Old 03-02-2015, 08:12 PM   #8
_Ogre
_Ogre's Avatar
agreed
shop air compressor timer
Old 03-02-2015, 08:35 PM   #9
wahl4m
my p-30 frame donor was an independent front chassis,rear was a bigger hd unit / so i bought a late model {at the time a 2009? } 1 ton dually rear -14 bolt axle - bolted right in ,w/new u-bolts and had the rear spring eye un rolled and rolled the opposite way /actually lowered vehicle ! and removed some xtra leafs . the donor chassis was a box -tool truck that hauled alot of weight! the steering box looks like it will work? maybe roll it back a tiny amount or use a "borgeson" u-joint ! i have it stored away ,need to drag it out , i had peeled the roof off to remove critter debris and trash /between the inner & outer and paint ,seems like it had a million screws !its a unfinished project that i need to get finished ! i always need a vehicle that will haul a trailer somewhere,plus it has lots of lay-back and stretch area -plus its possible to sleep in the rear! thanks mike
Old 10-11-2015, 10:38 PM   #10
wahl4m
whats the latest on your bus ???? got anymore done ? any ideas on the build ? mines still setting ,too many other builds in the shop ! thanks mike
Old 11-30-2015, 10:48 AM   #11
63 & 64 Bowties
and a few others
Originally Posted by HOTFUN View Post
Looks like he is gone too. I am jumping in with my off brand old project bus. A 1935 Dodge chassis with a Wayne Streamliner bus body. I was thinking of ordering a new Dodge 3500 2WD 167" WB dually cab/chassis with a 6.4 Hemi for the body to ride on. I got in my mind this will make an awesome reliable tow and travel rig with a classic bright yellow 30's bus body. Any concerns with fitting this new chassis underneath as I know I am going to have to widen the fenders a bit up front? I need some front sheet metal so I also was looking toward finding and utilizing a 36 to 38 Dodge 1.5 ton front clip for some more room under the hood for coolers and such.
More to come as this isn't a project for the faint hearted weekend dreamers and probably still take me several years to complete too...
Looks like a fun project for sure. You can start a build thread on this forum in the Alternate Tinkerings area.
