01-13-2015, 08:41 PM | #1 |
1971 K20 Suburban parts F/S
Here are the K20 Suburban parts from our pick up thread. Please ask any questions you may have. I can take photos of any parts needed.
To avoid possible confusion, we ask that you try to respond in the thread(s) for parts listed with in the thread. All prices are plus shipping. Shipping via UPS, USPS, and freight truck. Payment via Paypal, MO, and cards over phone. PHOTO 1 Rear bumper brackets RH and LH...25.00 each Lower gate hinges with bolts worn bushings...10.00 each rebuilt 45.00 pair (2) Lower gate strikers mounts to body side for latches w/bolts and shims...12.50 SOLD Lower gate latches...12.50 each Upper gate supports (holds up hatch)...15.00 each Lower gate straps...12.50 each with bolts Tail light housing...10.00 Back up light housing...7.50 Tail light lens minor fade on top...15.00 Back up light lens...7.50 Gas cap minor ding...5.00 Ign cylinder, door cyl's., and hatch bottom/cyl....40.00 SOLD PHOTO 2 Front door panels LH ruff, RH has tear metal looks ok...40.00 pair Rear door panels both need re-glued to metal some small tears...45.00 pair Rear compartment forward panel (left) very decent for age...25.00 Rear compartment panel, right needs edges re-glued. Has speaker hole. speaker hole cut out included... 25.00 Rear compartment RH filler at spare...20.00 SOLD Arm rest for front doors (two) sun baked/faded...10.00 each Sun visors great color has old school clip marks...10.00 each SOLD Sill plate for rear door some rust on bottom side. Top would clean up for DQ...20.00 Roof bows...on hold SOLD Stationary small glass with rubber...17.50 each Window rear regulator RH very nice...35.00 Window rear regulator LH very nice...35.00 Primary dome light with pig tail. This is a Suburban only piece...7.00 (3) access covers for rear gate...5.00 each SOLD (4) rubber plugs for barn doors hinges...20.00 SOLD (25) hinge and gate hardware access plugs...20.00 SOLD Chrome bezel trim for gate push button...25.00 SOLD Mounting plate for lower gate push button...15.00 Latch for upper gate, mounts in lower gate...12.50 Fuel filler neck with hoses...35.00 Also in separate photo is additional rear compartment panels off a 1972. Card board on all is wavy. PHOTO 3 Rear compartment panel (right) some split edges need re-glued...25.00 Rear compartment panel (left) rear few tears...30.00 Rear compartment panel, (left) forward minor cut...25.00 Thank you for the interest. Last edited by DLTruck1973; 02-10-2015 at 06:59 PM. |
01-13-2015, 09:16 PM | #2 |
Re: 1971 K20 Suburban parts F/S
I would be interested in the following parts: photo 1 - (2) lower gate strikers with shims and bolts, (3) access covers for rear gate, (4) rubber plugs for barn door hinges, (25) hinge and gate hardware access plugs. Photo 2 - rear compartment rh filler at spare, (2) sun visors. Let me know total with shipping and if paypal works. Thanks, Rich.
01-13-2015, 09:21 PM | #3 |
I will take (3) access covers for rear gate...5.00 each
(4) rubber plugs for barn doors hinges...20.00 (25) hinge and gate hardware access plugs...20.00 shipped to 77510 if Boe3 passes Thanks, Mickey |
01-13-2015, 10:30 PM | #4 | |
I will get you a total tomorrow. Can I get your zip code for a shipping quote? Thank you for the interest, Thomas |
01-13-2015, 10:32 PM | #5 | |
You are second in line for all of the above if Boe3 passes. I may have some more access plugs but will have to check. Thank you for the interest, Thomas |
01-13-2015, 10:38 PM | #6 |
Thanks Thomas
01-13-2015, 11:31 PM | #7 |
Cluster King
Subscribed
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
01-14-2015, 06:22 AM | #8 |
60641
01-14-2015, 02:17 PM | #9 | |
Let me know if interested and I will get you taken care of. Thank you, Thomas |
01-15-2015, 11:05 AM | #10 |
Would you by chance have a key for the ignition and door lock cylinders. If you do I would take them shipped to 37303. Thanks
01-15-2015, 01:00 PM | #11 | |
$37.50 shipped to your door. Let me know Thank you, Thomas |
01-15-2015, 01:50 PM | #12 |
Hi Thomas, it was getting close to the end of my break time so i was typing fast. Do you have a key for the set you have listed with ign. tumbler, door locks and the hatch cyl. Sorry for being confusing and repeatitive.
Thank you |
01-15-2015, 02:21 PM | #13 | |
No problem. That does change things a little and I will have to get back with you. Hold tight and I will make sure. Thank you, Thomas |
01-16-2015, 05:37 PM | #14 | |
I have everything for the Suburban, ign tumbler, doors (left and right) and rear hatch button. $40.00 plus shipping of $5.25 for a total of $45.25 Let me know, Thank you, Thomas |
01-16-2015, 08:13 PM | #15 |
Interested in the rear dome light. Does it go above the 2nd row seat ? How does it tie into the front overhead dome light ?
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-16-2015, 08:33 PM | #16 | |
Hi Mario, Yes the dome light does go above the second row seat. It has a separate harness that runs up the windshield pillar and then back overhead to the dome light. The rear dome light has a very short pigtail on it un like the pick up style dome lights. Now the question is do I have the harness to hook the rear dome light up. I believe the answer is yes but I need to put my hands on it to be sure and what the condition is. I may have to get back with you on Monday for that. Thank you for the interest. Thomas |
01-16-2015, 08:48 PM | #17 |
Please let me know if you can track down all the parts for the second dome light. Thanks, Mario
01-16-2015, 08:56 PM | #18 |
Any chance you have the mounting brackets for the rear seat? Thank you!
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
01-16-2015, 08:58 PM | #19 |
01-16-2015, 08:59 PM | #20 |
01-17-2015, 02:51 PM | #21 |
I will take the Suburban ign., door, hatch button lock set and key. Please send payment info.
Thanks. |
01-17-2015, 03:02 PM | #22 |
01-17-2015, 11:29 PM | #23 |
Paypal has been sent.
Thank you. |
01-17-2015, 11:32 PM | #24 |
01-19-2015, 01:43 PM | #25 |
