02-01-2015, 03:18 AM | #1 |
New to me 1969 Suburban Custom 10
Just picked up a 1969 Chevy Suburban Custom 10 this week. 112,000 original miles. 350 v8, 4 barrel carb and I believe a TH400 automatic trans with a trans cooler. 3.73 limited slip rear end from the factory. Power steering and power brakes. Runs great and is all stock. I repaired the tail light switch tonight and I need to go through the Heater switches as the fan won't turn on. Not sure why yet. My long term plans are a static drop with a disc brake conversion, tinted windows, rust repair and paint. It is going to be my daily driver.
http://s901.photobucket.com/user/Mcl...?sort=3&page=1 |
02-01-2015, 01:12 PM | #2 |
The Older Generation
Re: New to me 1969 Suburban Custom 10
Looks like a nice truck. The main heater switch is on the right side of the heater slide control bracket, under the dash. There is also a resistor in the top of the interior heater box behind the glove box liner. First thing I would do is to pull the wire off of the blower motor under the hood and test the wire for power with the switch and key on. Also make sure that the ground wire from one of the blower motor mounting screws to the firewall is not broken or corroded at either end. If you remove the connector from the resistor pry it up gently with a small screwdriver as the resistor block can be very brittle and break easily. The two screws that hold it in the heater box are 5/16". Also the squirrel cage could be full of mouse nests and it won't allow it to rotate. LockDoc
02-02-2015, 06:34 PM | #3 |
Lockdoc, thank you for the information. I went ahead and bought a new face plate, levers, cables and heater switch as mine seems to be pretty shot anyway. I will check those other things you suggested and hopefully have it all fixed soon.
Loving this Suburban so far. I had a 66 GMC Suburban for awhile which I thoroughly enjoyed but man, I'm very pleased with having power steering, power brakes and a tried and true 350 v8 under the hood. I can't wait to restore/modify this burb as time and money allow. |
02-02-2015, 09:42 PM | #4 |
Thats a great lookin 'Burb.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
02-02-2015, 11:15 PM | #5 |
Prestige Worldwide
Great looking Suburban!
02-02-2015, 11:16 PM | #6 |
here are your pics
1968 Chevy C-10 Suburban - 350/350 1969 Chevy C-10 Panel Delivery - 454/400 1972 GMC K1500 Jimmy - 350/350/np205 1978 Chevy Corvette Silver 25th Anniversary reddit.com/r/chevyc10 <-Join it! |
02-03-2015, 12:54 AM | #7 |
Thanks for the replies and for posting my pics on the thread. For some reason my computer wouldn't post them last night. I thought the files might have been too big.
02-03-2015, 11:36 PM | #8 |
Nice Burb!!
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
02-03-2015, 11:38 PM | #9 | |
No problem. The new parts should make it easier. Let us know if you have any more questions. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-04-2015 at 12:29 AM. |
