02-03-2015, 07:52 PM | #1 |
Pwr rack conversion
I just got done blasting ,painting and reassembling the frame and suspension on a 69 short bed. My steering box is leaking so instead of getting another and all the drag links and tie rod ends I figure I'll go ahead and put a pwr rack in it .
Does anyone have any advise on what kind of rack to get? It has the original steering pump. but it can also be swapped out... I have welder and fab skills to get it in I just need to know which ones are the best to use. |
02-04-2015, 09:29 AM | #2 |
Re: Pwr rack conversion
I know that someone makes a kit to do this "unisteer I believe" but I don't know of anyone that has fabricated their own version.
02-04-2015, 09:42 AM | #3 |
02-04-2015, 09:48 AM | #4 | |
I figured I could save a bunch of cash fabing it in myself if I knew what to start with...I guess I could get the tape measure out and take a walk through the junk yard too see what ones will work if I have too. If the rack costs 200.00 and the kit runs 900. that leaves 700. for a bracket and two hoses ....I'm more of a "ruin it yourself" kind of guy and mabee just a little cheap too. Last edited by deadbodyman; 02-04-2015 at 09:58 AM. |
02-04-2015, 12:15 PM | #5 |
On mine i have a late 70s to early 90s mustang r&p. That`s what porterbuilt designs there dropmembers around.
My build thread!! http://67-72chevytrucks.com/vboard/s...d.php?t=474018 |
02-04-2015, 01:39 PM | #6 | |
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
02-04-2015, 04:14 PM | #7 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
02-04-2015, 04:25 PM | #8 |
unisteer and no limit make the bolt in kits...you can use the 79-93 stang rack, and I've heard of using a t-bird rack too...there are a couple of build threads floating around but I'm not sure if they ever got it completed....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
02-04-2015, 05:18 PM | #9 |
If I had to guess I'd say the T-Bird and Mustang rack is very dang near the same. I would try the 99-07 Silverado rack if it were me trying this and I have thought about it as well. But I would say the Silverado cause I have a ton of those years laying around my place junked out and the parts are everywhere. Jim
02-04-2015, 09:13 PM | #10 |
Chance
Just get your ps box rebuilt. I had a parts store ps box that I kept returning because it always leaked. I sent that cardone ps box to Blue Top Steering and it has not leaked since!
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
02-05-2015, 08:01 AM | #11 |
I recently ordered the Unisteer kit as a custom order as I was not needing the power steering pump and remote tank/lines etc. I ordered it through Summit Racing and used my NHRA racer discount. I don't have the free time to hunt down a rack that might work and then deal with getting it mounted. Direct bolt on is worth alot in my book. The one from No-limit is nice but requires more work on install.
-1998 Formula WS6 1LE- LSX 427 4.58 @ 162 mph, 1.12 60' 2017 Silverado 3500 High Country DRW DMAX, 20" Fuel Wheels 1972 Chevrolet C10 Cheyenne - SOLD RaceWire Solutions |
02-05-2015, 08:58 AM | #12 | |
02-05-2015, 11:18 AM | #13 | ||
Looking at www.rockauto.com it look like the Silverado 1500's in those years had R&P Steering.
Just under 400 bucks with a core charge. Gary
02-06-2015, 11:13 PM | #14 |
laying low
To my knowledge Chevy trucks have only had a recirculating ball steering sector such as this one. Can someone post a pic of a factory installed rack and pinion on a full size GM truck? I'd like to see it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-06-2015, 11:36 PM | #15 | ||
I'm just glad to be here!
I used the No Limit kit on my son's '82. Link is in my signature. The kit uses a modified rack from the Silverado. The passenger side housing is cut off and rotated to have the lines in the front of the rack then welded back together. It's a great kit and works very well.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
02-07-2015, 12:21 AM | #16 |
laying low
Thanks. I have never seen r&p on GM trucks.
My 3 trucks are 4wd so they have the conventional steering sectors.
02-07-2015, 09:37 AM | #17 |
Old member
Just Google R&P on 71 Chevy trucks.
