02-05-2015, 10:06 PM | #1 |
Adding Disc and lowering Fr&Rr...
Ok I have been reading threads and searching sites for a week... I want to lower my 68 3/5(?) and upgrade brakes from non power drums to power disc. I also want to change from the 6 lug to 5 on 5 lug.
I have seen many kits to do one or the other, but nothing that does both. I am niether for nor against kits or piece mealing it out... which ever way to get the parts together to get the job done. So anyone have a parts list or manufactor that can help me? Jimmy |
02-05-2015, 10:06 PM | #2 |
67-72 parts collector,…
Re: Adding Disc and lowering Fr&Rr...
02-05-2015, 11:14 PM | #3 | |
If I order the axle conversion from them, what rotors and calibers will I need? And when you order the 4/6 drop kit for $799 you get the 2 1/2" drop spindles as do you when you get the disc brake conversion kit for $759??? Can't use two sets of drop spindles... And do these all bolt up to my stock A-arms? Jimmy |
02-06-2015, 12:49 AM | #4 |
Moderator
Call them and talk to Stan. He will fix you up with what you need and answer your questions.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
02-06-2015, 01:24 AM | #5 |
http://www.classicperform.com/Store/...6772GSK-5D.htm
I haven't used this kit, but this is one I was considering because I am looking to do the same thing you are looking at on my '67. The thing that looks good to me on this one is it comes with everything, which is a huge selling point for me. The only thing this doesn't include that I would need for my truck is rear axles to convert them to 5 lug, but I am leaving the rear as drum brakes. |
02-06-2015, 09:02 AM | #6 |
Look in the review area for feedback from members before you
order from CPP. You have been warned.
02-06-2015, 09:53 AM | #7 |
I'm considering doing almost the exact same thing to my 70 except I have power drums now. still thinking about replacing the booster and master though. I'd be interested to see what you end up going with. I have a little time before I pull the trigger on my upgrade, so please post who you go with and the results you get.
02-06-2015, 01:45 PM | #8 |
I do know that Early Classic offers a kit that combines the 4/6 drop kit and disc brake conversion kit for $1299. But that's as far as I got. Give them a call or email them at sales@earlyclassic.com. They're usually pretty good at getting back to you.
02-06-2015, 02:38 PM | #9 |
If you get the cpp kit plan on using different shocks mine lasted less than a month
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
02-06-2015, 05:38 PM | #10 | |||||
Called Stan...very knowledgeable guy! He is emailing me all the prices! Quote:
Thanks for the heads up! Quote:
I plan on using the kits available from ECC! Stan can put a kit together for your personal needs! I will not be tearing into this project for another couple months, just buying parts ahead of time. Quote:
Just got off the phone with Stan! Very impressed with him. Quote:
Not going with CPP.... |
02-06-2015, 05:44 PM | #11 | |
Senior Moment
All my suspension is ECE , Front and Back
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
02-06-2015, 05:58 PM | #12 |
Ok, after talking to Stan at ECE (for an hour!) I think he has everything worked out for me.
I am going with the 4/6 drop for sure. Converting over to power steering(thanks to Stan!).Jimmy Last edited by Dustmaker65; 02-06-2015 at 06:10 PM. |
02-06-2015, 06:23 PM | #13 |
Moderator
Rear disc is unnecessary, unless you have open wheels and want some bling.
02-06-2015, 06:24 PM | #14 |
You will be pleased with ece ,they are top notch.
02-06-2015, 06:48 PM | #15 |
Rear disc is nice if you have money to burn.
Otherwise it's not neccessary. You are on the right track with ECE.
02-07-2015, 11:00 AM | #16 |
Hmmm...still patiently waiting for that email from Stan with parts and prices....
Jimmy |
