Old 02-08-2015, 06:36 PM   #1
85k30
85k30's Avatar
My '85 truck build
I found a little time between projects. So I thought I would put together a little build thread on my truck. This truck was actually my very first vehicle. I was just 16. I bought it from my neighbor for $1000, seems like forever ago. It had a little rust and two cracked cylinder heads and barely made it across the street to my house, but I didn't care!
The truck started out as a 1985 1/2 ton long bed Scottsdale with a 305. It had a/c, electric everything, cruise control, but rubber floor, and a standard trans. Someone had to have ordered it that way.
Same day I bought it, back in 2001:
85k30 is offline   Reply With Quote
Old 02-08-2015, 06:42 PM   #2
85k30
85k30's Avatar
Re: My '85 truck build
The next weekend we tore the engine down. Both heads were cracked between the two middle cylinders. My brother just happened to have a set of 305 heads laying around. A few hours later, it was alive! The truck actually ran quite well for sitting for several years due to the cracked heads. It only had 89,000 miles on it.
Old 02-08-2015, 06:45 PM   #3
85k30
85k30's Avatar
The next day!
Old 02-08-2015, 06:54 PM   #4
85k30
85k30's Avatar
I cant leave anything alone! My moto is "If it aint broken, fix it tell it is!"
The truck got a 4" lift kit, some 33" tires and wheels, and of coarse a roll bar with some kc lights.
Old 02-08-2015, 07:05 PM   #5
85k30
85k30's Avatar
The 305 did eventually die. The rings leaked so bad from having coolant in the cylinders for so long, that it looked like a bug sprayer going down the road. I had a 350 I just built for my 70 Camaro. But in the battle of all my projects, the truck always wins because its my favorite. So I swapped in the 350 with a tpi fuel injection system I got from First Injections.
Old 02-08-2015, 07:29 PM   #6
85k30
85k30's Avatar
I dropped the truck off at a friends shop to get the cab corners, and rockers replaced and to have him remove the cleats on the sides of the bed. I never liked them anyway. Boy was I surprised when I went to pick it up, The rockers and cab corners where installed, but the whole truck was in primer. He had decided it was time I painted the whole truck and not just pieces of it here and there.
Name:  L & T Motorsports 072.jpg
And so it began. I had to come up with a paint color, and fast. I always liked the two tone paint the truck had on it and wanted to stick with something similar. I also liked the brown and tan combo it had. So I settled on a more modern paint scheme with some newer colors.
Old 02-08-2015, 08:05 PM   #7
85k30
85k30's Avatar
The truck paint turned out great! But it need something else to make it stand out. I managed to buy an old '81 one ton from my brother, after he sold the engine and transmission out of it. I rebuilt the axles and installed a 6" sky jacker lift kit.
Name:  rear axle2.jpg
Old 02-08-2015, 08:13 PM   #8
85k30
85k30's Avatar
Here is a pic of the truck with the axles, lift, wheels and tires after a good cleaning.
Name:  cleaning truck.jpg
Old 02-08-2015, 08:28 PM   #9
85k30
85k30's Avatar
The truck looked awesome! but with the 1 ton running gear, big toyo rubber, and only a 350 small block, it was lacking in the performance category! I was on the hunt for a big block. I almost bought one. But my buddy told me of a truck that the local bank was auctioning off that was a repo. It was a 2005 Silverado 2500hd with a 8.1 and a 6 speed trans with only 75,000 miles on it. After looking on here at a few 8.1 swaps. Mostly Dirty Larry's truck, I put in a bid and won! I wasn't sure about the zf650 swap tell I saw K20Chevy's build thread.
Old 02-08-2015, 08:45 PM   #10
85k30
85k30's Avatar
Out with the old!
Name:  old engine.jpg
Clean and paint the firewall, and frame.
Old 02-08-2015, 08:54 PM   #11
85k30
85k30's Avatar
The donor engine.
After a run through and some shiny new paint.
Name:  fresh paint 8.1.jpg
The cast aluminum pieces didn't match the new shiny engine
Name:  stripped aluminum.jpg
Old 02-08-2015, 09:07 PM   #12
85k30
85k30's Avatar
I spent the next month learning how to polish aluminum
Name:  oil pan 4.jpg
Name:  pollished tensioner.jpg
Name:  polished throttle.jpg
Name:  finished valve covers.jpg
Old 02-08-2015, 09:10 PM   #13
85k30
85k30's Avatar
Here it is sitting in its new home.
Old 02-08-2015, 09:19 PM   #14
85k30
85k30's Avatar
The HUGE zf650 manual trans turned out to be the only challenge on this build. I had Offroad Design make a np205 with a 29 spline shaft to match the trans. I also had Trail Tuff Fab machine an adapter to bolt them together after a clocked it up and out of the way.
Old 02-08-2015, 09:28 PM   #15
cable666guy
cable666guy's Avatar
Looks killer ! Good luck with it !
cable666guy is offline   Reply With Quote
Old 02-09-2015, 12:37 AM   #16
85k30
85k30's Avatar
Thanks. It's been a fun project!
Old 02-09-2015, 01:16 AM   #17
85k30
85k30's Avatar
To get the transmission to fit I had to raise the tunnel about an inch and a half. I got a factory tunnel from a 4wd auto truck at the junk yard so I could cut a new hole for the shifter and also make a new opening for the np205 shifter.
Before
Name:  hole in floor.jpg
New, altered junk yard tunnel
Name:  new hump before weld.jpg
After trimming and welding and some seam sealer.
Name:  floor seam sealer.jpg
I also had to cut a whole in the floor to clear the drive line brake.
Name:  t case hole.jpg
So I hammered out a new hump to cover it up.
Old 02-09-2015, 01:34 AM   #18
MTCK
MTCK's Avatar
Very cool truck.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-09-2015, 01:44 AM   #19
85k30
85k30's Avatar
After a little paint
Name:  finished floor splice.jpg
Because the transmission and t-case are so long the cross members had to bolt on after the frame started to raise up to the bed. So they needed a little reworking.
Name:  rear cross member.jpg
Size:  41.1 KBName:  front cross member wedge.jpg
Name:  rear cross member 2.jpg
Size:  7.5 KBName:  rear cross welded.jpg
Old 02-09-2015, 01:56 AM   #20
85k30
85k30's Avatar
All cleaned up. ready for paint.
Name:  finished cross.jpg
Size:  8.5 KBName:  finished cross 2.jpg
I added a support for the t-case on the rear cross member.
Name:  rear support.jpg
and then made a skid plate for it.
Name:  finished t case rear.jpg
Old 02-09-2015, 02:23 AM   #21
85k30
85k30's Avatar
To make the clutch work, I had to use the master cylinder for the zf650. I tried to get the factory one to work, but it couldn't push enough volume to move the slave cylinder all the way. The problem with using the new one is. The factory one mounted flush at 90 degrees. The new one had to be mounted at I thing 16 degrees. Oh and it twisted in, not bolt on!
I made an adapter to bolt it into the factory holes.
Name:  master adapter.jpg
Name:  slave installed.jpg
Old 02-09-2015, 02:26 AM   #22
85k30
85k30's Avatar
I couldn't have a truck with an awesome paint job, and bad ass drivetrain with a stock interior. After searching for what seamed like forever. I came across a seat combo that looked great in a old square body. A fellow member, Carbon Crew put them in his truck, and it turned out bad ass! So I ordered up a set.
Old 02-09-2015, 02:37 AM   #23
85k30
85k30's Avatar
Next was the exhaust.
I have had 4 different exhaust systems on this truck in the past. And the thing I hated about all of them, was that they rusted! I have tried hpc coating, ceramic, aluminized, and eventually they all corrode. So I knew I wanted stainless this time.
I have 304 stainless 1 7/8 full length headers with custom 3" mandrel bent stainless pipes, stainless Magnaflow mufflers, and v-band clamps throughout thanks to Turbo Lab Racing in Orem, Utah.
Old 02-09-2015, 02:46 AM   #24
85k30
85k30's Avatar
I made my intake pipe with parts from Spectre Performance, and a K&N filter that was on my truck before. Just had to make a support bracket for the tube to sit in.
Old 02-09-2015, 02:48 AM   #25
85k30
85k30's Avatar
The truck got a new bumper from LMC Truck to finish off the front.
Name:  new bumper.jpg
