Old 02-16-2015, 12:42 AM   #1
bhill00
Fan blower motor not working
69' C20 wth stock 396 and AC. I replaced all seals on Heater box and fan motor, reassembled everything and the fan motor worked at all speeds for about a month. Fan motor will not turn on with the switch, connected the fan to the battey and fan runs. I had an extra switch, replaced the switch,checked the fuses and still not working. Any thouoghts about what I should check next?
bhill00 is offline   Reply With Quote
Old 02-16-2015, 12:59 AM   #2
leftybass209
leftybass209's Avatar
Re: Fan blower motor not working
Welcome! It's quite possible neither switch is working. Make sure you still have a good ground. May be time to get out your multimeter.
leftybass209 is offline   Reply With Quote
Old 02-16-2015, 01:16 AM   #3
bhill00
Thanks Lefty. Really enjoy the forum, have used it many times to solve issues. I will get the volt meter out and make sure I have juice running to all the right spots.
blower, fan, fan switch
