Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-16-2015, 12:58 PM   #1
mattcrp1
mattcrp1's Avatar
Harbor Freight Welding Cart (Review)
Hi all, I know it might have been covered before but after saving some money from my side jobs and getting a 20% discount coupon in the mail I finally bought a Harbor Freight basic welding cart. It came out to about $39.00 before tax, and took about 10 minuets to put together.
I am happy to have my welder finally on a convenient portable cart, and not under my bench. As well as keeping all my equipment in one spot. Not a bad product for the money.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-16-2015, 01:18 PM   #2
flashed
Re: Harbor Freight Welding Cart (Review)
Looks pretty good for the money spent .
flashed is offline   Reply With Quote
Old 02-16-2015, 01:57 PM   #3
portrodder
Nice score, I've been using that same Harbor Freight cart for over a year now with no problems.
portrodder is offline   Reply With Quote
Old 02-17-2015, 01:52 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I looked at these when I got my welder but I just have never been able to wrap my thought process around a manufactured welding cart. I've always built them as a first project for the welder to learn it a bit. My cart is almost like that only built from .120 angle and has the non turning wheels mounted narrower with one on either side of the bottle. It also has a handle(w/clamp storage) and is big enough to have a bottom shelf that holds a cutoff saw and a couple of grinders. It's really not enough different to matter but I only have about $25 in it and the experience out of building it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-19-2015, 12:20 AM   #5
Rod Run
Rod Run's Avatar
I originally bought that one, but once I got it assembled it was about a quarter inch to narrow for my welder.
Dissembled it, brought it back and got their one with draws. To bad that one cost me over triple the price
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 02-19-2015, 01:55 AM   #6
tinydb84
tinydb84's Avatar
I got one for my Hobart 190. Doesnt fit enough for me to open and close the side panel without having to tilt it. I just level the side panel slightly open.
David
Instagram: myfabguy
Old 02-21-2015, 11:34 PM   #7
mattcrp1
mattcrp1's Avatar
Its like this cart was built for my lincoln 140. Fits perfect.
IG mattcrp1
Old 02-27-2015, 04:01 PM   #8
NONHOG
NONHOG's Avatar
made a few minor upgrades to mine. I want to change some stuff. I just got a much taller argon mix bottle and that made the welder move forward.
I'll dig in to next round of upgrades someday.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 03-06-2015, 10:34 AM   #9
mattcrp1
mattcrp1's Avatar
Nice set up.
IG mattcrp1
Old 03-06-2015, 12:05 PM   #10
72bowtiestepper
Thats what I did with mine too....this way you can tailor it to fit your rig the way you want and get used to the way your welder works. I got some angle iron & 1/8" plate cold roll from a steel supply place near me. A set of back wheels & casters for the front....you are good to go for cheap !
72bowtiestepper is offline   Reply With Quote
Old 04-25-2015, 12:16 AM   #11
mattcrp1
mattcrp1's Avatar
I use my welder a lot more. I am really glad i bought this.
IG mattcrp1
Old 05-22-2015, 01:39 PM   #12
zamboni2354
I bought one of those for my first welding cart. The swivel wheels never worked good so I replaced them with some wheels at HF...worked really nice after that..I ended up giving it to a coworker after I bought this one from HF:
it's a lot more expensive (150 on sale) but is a really nice cart.
jeff
zamboni2354 is offline   Reply With Quote
Old 05-25-2015, 06:15 PM   #13
dougf
dougf's Avatar
Nice work guys. I use the 3 drawer cart and I love it.
dougf is offline   Reply With Quote
Old 06-16-2015, 05:17 AM   #14
Chevy_mud_truck
Chevy_mud_truck's Avatar
Just a little tip for you guys with mig welders I was having some trouble out of my liner had to replace it a couple times and was talking to a guy that work in a fab shop and he said my problem was I was rolling lead up he told me not roll it up if possible if I had to to try make the lope as big as I could I started doing it haven't had to Change one scents and I'm working on my third 44lb spool of wire
Chevy_mud_truck is offline   Reply With Quote
Old 06-16-2015, 08:55 AM   #15
ERASER5
ERASER5's Avatar
Mean while in Australia.... How do you keep your drink in that cup?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
