02-17-2015, 11:47 PM | #1 |
Well Crapp!
My exhaust manifolds came down with measles. Actually after 3 years on my LS conversion the ceramic coating has failed on my Hooker manifolds. They were actually black when I first purchased them and eventually turned gray. That was my first disappointment of coarse so just a warning don't order the black unless you want gray. Other then the color and the crapy coating I still like the fit and construction. Now I've got to pull them off for a recoat and hope I don't snap any bolts. I did use antisieze when installed. Anyone else have this problem.
02-18-2015, 12:26 AM | #2 | |
The Older Generation
Re: Well Crapp!
I just purchased a set but I got the un-coated ones. I am going to try the POR manifold paint on them. Did you temper or "cure" them as stated in the instruction sheet that came with them? Sounded kind of involved to me..... LockDoc
02-18-2015, 12:36 AM | #3 |
Re: Well Crapp!
I bought some used F-body manifolds for my swap and I'm going to try out the POR manifold paint as well.
02-18-2015, 01:53 AM | #4 |
Re: Well Crapp!
02-18-2015, 01:55 AM | #5 |
Re: Well Crapp!
I have that por heat paint maybe I should try that first before paying someone to recoat. How do I remove this ceramic coating?
02-18-2015, 02:34 AM | #6 |
meowMEOWmeowMEOW
Re: Well Crapp!
The only coating I've ever see hold up is the o.g. jet-hot coatings.
02-18-2015, 08:33 AM | #7 | |
Re: Well Crapp!
http://www.jegs.com/i/ARP/070/434-1202/10002/-1 Last edited by homemade87; 02-18-2015 at 08:41 AM. |
02-18-2015, 11:39 AM | #8 |
Boosted Member
Re: Well Crapp!
I've had really good luck with the VHT ceramic flameproof black paint. It's been holding up on my turbo hot-pipes for a couple years now...and they get WAY hot.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
02-18-2015, 02:20 PM | #9 |
meowMEOWmeowMEOW
Re: Well Crapp!
Is that the stuff that you HAVE to run HOT right after you paint it so it bakes on?
02-18-2015, 02:38 PM | #10 |
Registered Cruiser
Re: Well Crapp!
Yes, but you can bake it in the oven initially and then cycle once they're on the motor. That's what I used and did the baking before cycling on the motor. Stuff works great, still going strong going on two years now.
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
02-18-2015, 03:53 PM | #11 |
Boosted Member
Re: Well Crapp!
I use a propane torch to cure it in between coats. Has held up better than the high dollar "ceramic" coating I had on the turbine...
02-18-2015, 04:26 PM | #12 |
meowMEOWmeowMEOW
Re: Well Crapp!
Thought that was a snake-oil thing they tried back in the GN days (At least the actual impeller being coated). Sooo, did it eat the turbine?
02-18-2015, 04:54 PM | #13 |
Boosted Member
Re: Well Crapp!
Sorry I should have been more specific. I meant the turbine housing...not the turbine wheel. lol
02-18-2015, 05:43 PM | #14 | |
Re: Well Crapp!
Hey wasted when you cure with the torch, do you just spray again or re-wipe down the manifolds in between coats. This sounds like a good idea. |
02-18-2015, 07:37 PM | #15 |
Re: Well Crapp!
Here's what member Low Elco said about the POR manifold paint.... "Also, POR makes a manifold gray that works great. Almost a year on ours, looks like the day they got painted." LockDoc
02-18-2015, 07:57 PM | #16 | |
meowMEOWmeowMEOW
Re: Well Crapp!
The exh bolt issue is related to the different expansion of the aluminum heads on those bolts. ARP bolts/studds won't break off. You can use anti seize on any of them to help the problem.
02-18-2015, 08:50 PM | #17 | |
Boosted Member
Re: Well Crapp!
I was curious about the truthfullness of the "flameproof" name. Yep. Can't burn it off.
02-18-2015, 09:13 PM | #18 |
Re: Well Crapp!
02-18-2015, 10:00 PM | #19 |
Re: Well Crapp!
You can buy 100 of the 8mmx1.25 25mm in class 10.9 zinc coated for $25 on ebay or at a fastener store. Why should I spend more than that for only 12 bolts?
02-18-2015, 11:19 PM | #20 |
Re: Well Crapp!
On LS engines, ARP exhaust manifold bolts are worth every penny! I have seen to many pop the heads off 10.9 grade bolts.
02-19-2015, 12:54 AM | #21 |
Re: Well Crapp!
02-19-2015, 01:22 AM | #22 |
meowMEOWmeowMEOW
Re: Well Crapp!
How long will it take you to pull all of those out of the head, one-by-one? I place at least a few $$ on my sanity and my fingers.
02-19-2015, 04:18 AM | #23 |
Re: Well Crapp!
I thought thats how you tell how many miles are on an engine, the outer bolts pop off right at around 100k....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-19-2015, 01:53 PM | #24 |
Re: Well Crapp!
Can anyone recommend on how to prep these if I choose to spray with VHT.
02-19-2015, 03:18 PM | #25 |
Re: Well Crapp!
Thats true, my Dad's 2000 Silverado has some broken bolts I have to fix, it's got 110k on it now.
