West coast mirrors
Is there something about where the West Coast mirrors should be located? I am not sure if something like that would be in the assembly manual or not. If so I guess I should buy one, unless someone can post it for me.
I was going to buy the from Wess at Classic, but he stopped selling them, but said the Grote ones are similar. They are similar and seem to be very well made, but the mounting locations are not the same, it seems, as the holes that are already in my door. I am not sure if I should try to make the existing holes work, or weld those holes closed and mount them where I want them. I am just wondering if the holes in the door are factory or not. This is what I bought ![]() |
![]() Join Date: Oct 2011
Re: West coast mirrors
I am not familiar with those particular Grote mirrors. they look nice!
any or all of there holes may be different than OEM. http://67-72chevytrucks.com/vboard/s...d.php?t=592303 hope this works for you.
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
![]() Join Date: Jan 2015
I am familiar with those mirrors but not in mounting them to a Suburban. They are very good quality mirrors. You can get replacement heads for them that are heated. Very nice on cold snowy days!
http://www.awdirect.com/heated-repla...30511/mirrors/ ![]() |
The mirrors your asking about are Camper style mirrors . Here is a thread to look at.
http://67-72chevytrucks.com/vboard/s...Camper+mirrors
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
#5 | |||
RPO DF2 for the stainless "Camper" mirrors.
Good choice of threads there CrewCab59! :-)
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
These may not bolt up exactly to factory holes. The two factory lower braces are separate parts. On these replacements, as well as later GM, the lower braces are made as one piece. So, no option on spread between the two
They did bolt into the factory holes, but since the lower legs are a little shorter, it pulls the mirror down and they are at an angle now. You can also easily spread the holes and tweak everything. It looks terrible in the factory holes, but it is a mirror for now. it also vibrates a lot as I drive on the highway.
I have to figure out what I want in the end, as I don't really like them as much as I though I would, then I can close up all the holes in the door and put the vibration damper and sound damper, make some door panels. |
The Older Generation
There is a metal strap or connector that is welded inside the door. It connects the inside and outside of the door together. If it is cracked or broken it will allow the outer door skin to vibrate, making the mirror shake. I had to take my door apart and weld the connector back together to make my driver side mirror useable.... Just a thought. Here is a thread I posted with some pictures of the metal strap. http://67-72chevytrucks.com/vboard/s...d.php?t=633866 The '72's are the only year with the screw. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-03-2015 at 05:23 PM. |
Yeah, mine is probably broken. I was able to squeeze the inner and outer panel with my hand with the window down. Thanks for the tip! I'll have to fix that when I pull the glass out for weatherstripping
I'll probably go with real West Coast mirrors or something, I just don't like the campers now that I have one on there |
#11 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=660294 Be sure and read through the whole thing. I kinda posted the how to's in reverse order.... ![]() LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-04-2015 at 01:19 AM. |
Yeah, you could flex the one piece lower brace assembly to fit holes, but I was saying it just won't work right...which you know by now
#13 | |
#14 |
I actually took off an aftermarket mirror and added the mirror that had what appears to be an original type mount. The holes for the camper mirrors were not factory so I filled them. I think this looks better and gives me the best of both worlds with the mirror I wanted with fewer holes in the doors! Got them from Brothers I think.
