02-19-2015, 02:57 PM | #1 |
LS Engine Wiring
Guys I could use a sanity check on my engine wiring. Wiring up an 07 LQ4 using a PSI standalone and Speedway 12 circuit harnesses.
• PSI harness connect to the same terminal as the battery on the back of the starter • PSI harness connects to the 4-pin plug on the alternator • PSI harness connects to the ignition switch (On) – power during on and cranking • Body harness connects to the battery on the back of the starter via the fused link. • Body harness provides connection between ignition switch (start) to the NSS then to the starter • Need a wire from the lug on the back of the alternator to the battery terminal on the starter • In the body harness the following connections are not required: alt power, alt exciter, coil, choke Questions: • What is alt power in the body harness used for? Isn’t the harness getting power from the battery/starter terminal? • Using a universal ignition switch – the IGN or ON has power during on and cranking? • In the body harness the “ignition switch ign” brown wire does what? http://psiconversion.com/tech_articl...structions.pdf http://static.speedwaymotors.com/pdf/910-64017.pdf I think that’s it for now. Thank you in advance. |
02-23-2015, 01:55 AM | #2 |
Re: LS Engine Wiring
Thoughts?
02-23-2015, 12:18 PM | #3 |
The Older Generation
Sometimes the weekends are a little slow on here. I don't have enough experience to help you out on this but someone will chime in. LockDoc
02-23-2015, 09:27 PM | #4 |
Henney,
I'm in Milwaukie Oregon and I have my wiring all done on my swap, if you want to come up and take and look at my setup. I did not use a PSI harness it is one from BP Automotive but they are all similar I think. I can't start it yet but can help with wiring. Shoot me a PM if you want. Rich |
02-24-2015, 06:06 AM | #5 |
Speedway has a great harness. Did you read the directions. The direction we're very detailed for the install. If I were you, I would install you car/truck harness first. I can't trouble shoot your troubles now, cause I need to the direction. Pm me your number and I will call you direct. I'll help as much as I can. Clark.
02-24-2015, 12:17 PM | #6 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-27-2015, 06:47 PM | #7 |
Thanks for the input guys.
LS that was exactly what I was looking for. |
