Old 02-21-2015, 02:55 AM   #1
hotcorner216
Smile 5.3l/4l80e swap parts list
Im sure this has been beat to death, with good reason, but maybe i just dont know how to look for it...but anyone has a parts list or rough guidline of parts needed to do the swap? Ive seen some here and there, some parts ill need but not a complete list...as of right now im just doing a straight swap...5.3l/4l80e in a 69 short...performance cams, intakes, ect probably wont be happening for another year or so, heres what i want and maybe i can get some direction or links to good threads with the info...
-Fuel injection
-A/C
-Power Steering
Thats all i can think of right now, importance in that order..any advice would be appreciated.
hotcorner216 is offline   Reply With Quote
Old 02-21-2015, 11:27 AM   #2
jessemthompson
Re: 5.3l/4l80e swap parts list
Check here.
http://67-72chevytrucks.com/vboard/s...d.php?t=456787
jessemthompson is offline   Reply With Quote
Old 02-21-2015, 06:08 PM   #3
hubba033
hubba033's Avatar
I'm swapping a 5.3 4l60 into a 72 heres most of what i've got so far.
Boyds gas tank w/fuel pump
fuel lines and fittings
fuel filter
o2 sensors
doug thorley headers (not required but pretty sweet)
top end gasket set
plugs and wires
gas pedal with tac and bracket from hartrob
PB trans crossmember
DD motor mounts
RnD Radiator
haven't decided on swapping oil pan yet
still need lots of little details - radiator hoses, mass air flow, belt, exhaust headers back, air intake setup, fuel filler setup, maybe shift linkage
not sure what all ill need with wiring harness yet too
hope that helps some...and if anyone else has more things or advice i need all the help i can get
72 C10 swb LS 5.3 LSA Blower/4l60 performabuilt
01 Pontiac Trans Am WS6
hubba033 is offline   Reply With Quote
Old 02-21-2015, 11:08 PM   #4
H20cooled
I bought a used MAF sensor from ebay that was for the similar year motor as my swap motor, for belt again bought off Amazon just matched year and vehicle info. Exhaust is hard you will probably have to modify anything you buy to work, I bought the Magnaflow setup for my truck that is supposed to be bolt in but there is no way it will fit without modifications. Air intake again but from ebay just got a "cold air" setup I got one with a K&n filter for $150, I had to make some support brackets to hold the setup but it was easy to do, not using the cold air box as it does not fit. Shift linkage the Lokar ACA-1800 seems to be what everyone is using for column shifters.
Hope this helps
Rich
H20cooled is offline   Reply With Quote
