Old 02-22-2015, 08:44 PM   #1
808turbo
Code p0151 HELP!
Ok, a little info engine is a Ls1 out of a 1998 Camaro, harness was modified buy Howell. When I first fired the engine I noticed the right side exhaust was running rich, I didn't see the check engine light so I thought that maybe it would clear up with more run time being the engine sat for 6 months.
When I manually grounded the fan relay it thru a code p0481 and p0151. So now I have checked the o2 sensor, continuity from the plug to the PCM, and the voltage from the PCM, everything checks out.
Using a scan tool bank 1 shows voltage moving around in closed loop, bank 2 shows zero voltage in closed or open loop. I'm I missing something.
808turbo is offline   Reply With Quote
Old 02-22-2015, 09:34 PM   #2
clinebarger
Re: Code p0151 HELP!
Unplug the O2 sensor, The voltage feedback should be around 1/2 a volt (.500 millivolts), If voltage is still low, Un-pin the Bank 2 Sensor 1 signal wire at the PCM, If the voltage is now at a 1/2 volt....The signal wire is shorted to ground in the harness. If the voltage is still zero....Faulty PCM.
clinebarger is offline   Reply With Quote
Old 02-22-2015, 09:52 PM   #3
808turbo
Clinebarger,
So, unplug the o2, with engine running or off?
Old 02-22-2015, 09:58 PM   #4
808turbo
Ok, unplugged o2, key on showing .445 volts. So I need to unpin which signal wire? Low or high?
Old 02-22-2015, 10:17 PM   #5
clinebarger
Faulty O2 sensor if voltage returns after unplugging the 02 sensor. But, being a aftermarket harness....The O2 plug could be miss-pinned.
Swap the Bank 1 & 2 02 sensors & recheck.
Old 02-22-2015, 10:22 PM   #6
808turbo
Ok, I'll try swapping o2's.
