Lq4/4l80/np241 swap help
I'm getting ready to start my swap and I have a few questions. I'm using the pacific fab x-member and was trying to figure out location to mount to framerails. And what are my options for transfer case mounts? If anyone has done this swap in a 71 k5 ideas and pics would be appreciated.
1971 blazer 4x4 Awaiting lsx/4l80e swap |
Boosted Member
Re: Lq4/4l80/np241 swap help
Check out my build thread on the K10. I used a dirty dingo crossmember, but used the 4L80E/NP241C combo.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Did you leave the trans crossmember in the original location and just lined up engine crossmember based on that?
Also what shifter and linkage did you use on the t case
Boosted Member
I moved all the crossmembers based on where I wanted the engine.
I used a factory shifter from an early 90s suburban. Moved the hole to the passenger side, and modded the linkage a bit to work. It works perfectly.
