Old 03-25-2015, 09:20 AM   #1
solidaxel
solidaxel's Avatar
LS Oil Pan Gasket
I need to replace the oil pan and gasket
Are there better gaskets, or they all from the same supplier?
Is one better than the other?
Are all LS pan gaskets the same dimensions, will a 5.3 and a 6.2 and a 4.8 all the same part number?
Any "tricks" to replacing a oil pan on a LS engine?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-25-2015, 01:01 PM   #2
mej005
Re: LS Oil Pan Gasket
I bought the GMPP LS swap pan and it came with the gasket riveted on if I remember right. When you do reinstall the pan make sure the back of the pan is flush with the back of the block. There are instructions floating around here somewhere on the forum.
I can't 100% answer your question about size, but I am almost certain all will interchange with one another.
mej005 is offline   Reply With Quote
Old 03-25-2015, 03:06 PM   #3
solidaxel
solidaxel's Avatar
Thanks,
More research shows that they fit many different years and cars!
Ordered the parts from the local Chevy dealer!
LS 3 4L70E
Old 03-25-2015, 06:29 PM   #4
crazy longhorn
Fabricate till you "puke"
Use your bell housing , to line up the pan front to rear Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-26-2015, 02:22 PM   #5
solidaxel
solidaxel's Avatar
O K, I changed the pan to a Camaro and the iron block does not have the center side bolt holed drilled in the block, what are you folks doing with that?
LS 3 4L70E
Old 03-26-2015, 07:59 PM   #6
clinebarger
Are you talking about this bolt hole?
Don't worry about it, A lot of pans don't even have that hole. What Camaro pan are you using? 4th gen Camaro pans don't have that hole, 5th gen does.
clinebarger is offline   Reply With Quote
Old 03-27-2015, 09:33 AM   #7
solidaxel
solidaxel's Avatar
The pan is from a 6.2 crate engine
It is either that one or the next one to the front, I will look closer today
I looked at the old gasket and there was a smear of grey silicone at all four corners so I added a bit, very little now to find a inch Lb torque wrench
LS 3 4L70E
