Old 03-25-2015, 09:08 PM   #1
70ls1chevelle
68 Chevy swb,L96/6L90 swap,steering column ?
I just purchased a 2010 2500 chevy express van,with a L96/6l90.In my 68 Chevy short bed.
This steering column in the 2010 2500 van I bought that had the L96/6l90 has a steering column with cruise on the steering wheel and shifter on the column with PRNDM1 with push button manual shift on the column shifter,how hard would this be to use this column in my 68 as it works in the van ?
70ls1chevelle is offline   Reply With Quote
Old 03-28-2015, 11:10 PM   #2
gottattooz
gottattooz's Avatar
Re: 68 Chevy swb,L96/6L90 swap,steering column ?
http://www.67-72chevytrucks.com/vboa...d.php?t=468341
I stripped a 2004 GMC Savana 2500 and put the wiring harness, steering column, dash cluster, fuel pump and motor and trans into my 68 shortbed.
If you could post a picture of the steering column in question, I could probably give you a better answer. I removed the column shift, and installed a B&M light truck mega shifter. The two-wire sensor on the back of the shifter for mine was only a neutral safety switch.
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is online now   Reply With Quote
