03-28-2015, 01:01 AM | #1 |
Always on the hunt...
NOS tail light lenses/NOS back up light lenses
Fleetside pickup, blazer or jimmy full four piece NOS rear lens setup including a pair of 67-72 NOS tail light lenses, one 71-72 NOS LH reverse b/u lens and one 71-72 NOS RH reverse b/u lens. Set price is $200. add $15.95 for USPS priority insured shipment, if you have an earlier truck and need or want the 67-70 bullseye type b/u lenses add $75. and I will swap a NOS LH-RH bullseye b/u lens set in place of the two pictured later style b/u lenses. Mel
03-28-2015, 02:09 AM | #2 |
Re: NOS tail light lenses/NOS back up light lenses
I'll take a set with 67-70 backup lenses. Have a set of NOS gaskets for the lenses?
03-28-2015, 05:06 AM | #3 |
Ok, I can supply you with the earlier type NOS lenses but its a no on the NOS lens to housing gaskets, it may be an easier task to find NOS tail & reverse light housings with the seals already in place. I'll get you some lens pictures here in a bit, Mel.
03-28-2015, 08:44 AM | #4 |
Ok sounds good thanks. I'm also looking for a pair of 69-72 bucket seats.
03-28-2015, 09:11 AM | #5 |
Here is the full NOS setup with the earlier type reverse lenses that you requested. You'll get the below pictured pair of 67-72 NOS tail light lenses, one 67-70 NOS LH bullseye b/u lens and one 67-70 NOS RH bullseye b/u lens. Price is $275. add $18.15 for USPS priority insured shipment. On the buckets, per your earlier message it sounded like you just needed/wanted a pair of bare frames with LH adj. tracks and truck style RH fixed brackets? Mel
03-28-2015, 09:17 AM | #6 | |
Nice!! Just looking for a pair of buckets for my 70 4x4 restoration project. It would be nice to find a set with good foam. But if the foam is bad i can just have it replaced. |
03-28-2015, 10:26 AM | #7 |
Do you have another set of the bullseye backup lenses for sale?
1970 CST 4x4 collecting nos parts for this project 1972 cutlass owned since 1984 1972 cutlass conv 1970 Cutlass conv 1981 chevy shortbox 1986 grand national 2004 2500HD Crew Cab 66,000 miles |
03-28-2015, 01:38 PM | #8 |
If asking on availability in the form of a full 4 pc. rear NOS tail light lens and NOS bullseye b/u lens setup as pictured above, then yes I can supply you with that. If you are asking for the NOS bullseye b/u lenes by themselves, then no. Thanks for the inquiry, Mel.
03-28-2015, 04:07 PM | #9 |
Yes just needing the backup lenses.I already have nos tail lamp lenses . Thankyou
03-28-2015, 05:28 PM | #10 |
Shouldn't after market gaskets work on NOS?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-28-2015, 06:04 PM | #11 |
If the tail light lenses and the B/U lenses (at top) read 71 and they're mint I'll take them.
If not, I'd be interested in tail lenses that read 71, if they're super duper. Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-28-2015 at 07:16 PM. |
03-30-2015, 04:17 PM | #12 |
Need a set of taillight lens for 72 let me know if and how much thanx
03-30-2015, 07:44 PM | #13 |
Yes, the first pictured NOS setup (blue/white boxes) is available but only as a complete 4 pc. setup as listed, the second pictured NOS setup (gold/white boxes) has been sold/paid for. On the year part, I have had alot of NOS tail lenses over the years all GM produced/packaged at various different times some gold boxed, blue boxed, bagged and the later style plastic over cardboard packaged, and they all have the same "GUIDE 1T SAE STIA 67" molded onto the left hand upper edge of lense. Could you be getting the tail and reverse lenses confused with one another, I know that the reverse lenses had either the 67 or 71 molded into them? Mel
03-30-2015, 07:46 PM | #14 |
03-30-2015, 09:26 PM | #15 | |
03-30-2015, 09:58 PM | #16 |
03-31-2015, 12:35 AM | #17 |
Is there another full set for a 72 available?
Thanks, Lee
72 Ochre Blazer 69 Camaro Z28 Garnet Red 48 Willys (rolled) |
03-31-2015, 03:33 AM | #18 |
Mike, the above pictured 4 pc. NOS lense set (gold boxes) is headed your way. They were sent out USPS priority insured on Mon. 3/30, your projected delivery date listed on the postal receipt is Fri. 4/03. Thanks again, Mel.
03-31-2015, 03:36 AM | #19 |
Tony, the above pictured 4 pc. NOS lense set (blue/white boxes) is headed your way. They were sent out USPS priority insured on Mon. 3/30, and your projected delivery date listed on the postal receipt is Thur. 4/02. Thanks again, Mel.
03-31-2015, 03:39 AM | #20 |
03-31-2015, 09:14 AM | #21 |
Thanks for offering these great nos parts! I appreciate your help
04-03-2015, 08:41 AM | #22 | |
Any luck finding any more NOS tail/backup lenses? Thanks, Lee
04-03-2015, 01:00 PM | #23 |
Hey Lee, as of today 4/03, I have one 67-72 NOS tail lens and two 71/72 NOS 257/258 reverse lenses extra. We have more stored away but I am trying to stay out of my own tucked away NOS parts stash for three future builds as I would end up needing to replace them later and due to availability the prices aren't geting any cheaper. I have a call out to a couple others that I deal NOS with looking for another tail lens, will check back in with you if I am able to come up with one. Thanks, Mel.
04-03-2015, 04:50 PM | #24 | |
