Old 04-06-2015, 04:24 PM   #1
shawno72
C/10 junkie
shawno72's Avatar
Crate engine decoding.
Ok so I bought this 1970 lwb and the po said his dad had put a crate engine that he got from GM. I believe him but can't find any info on the numbers. Any help would be greatly appreciated. Thank you in advance.
Block number VF140027
Head number 14079267
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-06-2015, 04:26 PM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: Crate engine decoding.
Couple pics.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-07-2015, 12:29 PM   #3
shawno72
C/10 junkie
shawno72's Avatar
Ttt
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-07-2015, 02:13 PM   #4
leftybass209
leftybass209's Avatar
I also have a crate motor, and haven't found any information to decode it. What I can tell you about mine is, it probably started life as a 350/260hp, and it has the same block casting numbers as a known 350/290hp. I opened mine up and verified it was a 4 bolt main, and the specs for the Goodwrench 350 matched up (mine is at least 10 years old). The only difference between the two crate motors was a cam swap. All other numbers are the same.
Sorry if that doesn't help. Best of luck!
leftybass209 is offline   Reply With Quote
Old 04-07-2015, 02:42 PM   #5
shawno72
C/10 junkie
shawno72's Avatar
Thank you, I appreciate the input. I was assured by the po that it was a 4 bolt main, but aren't they all when you buy them
At this point I'm more curious about the valve size in the heads
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-07-2015, 03:05 PM   #6
leftybass209
Got you covered there as well. This is an excerpt from the article super chevy did on the gm crate.
"The 76cc chamber cast-iron heads (casting number 83417368) are fitted with 1.94/1.50-inch intake and exhaust valves"
I followed the ideas from the article and had my heads rebuilt with thinner head gaskets and back - cut valves. There's a lot of interesting info in this article series.
http://www.superchevy.com/how-to/463...-engine-build/
hope that helps.
Old 04-07-2015, 03:08 PM   #7
shawno72
C/10 junkie
shawno72's Avatar
hope that helps.
Great. Thank you.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-07-2015, 03:50 PM   #8
enaberif
If that VF # is the one behind the alternator that is a strange number.
enaberif is offline   Reply With Quote
Old 04-07-2015, 04:11 PM   #9
shawno72
C/10 junkie
shawno72's Avatar
It is stamped on the block on the little pad on the passenger side of the engine.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-07-2015, 04:52 PM   #10
NorCalC20LWB
FWIW, I also have a crate engine in my 72 with a front engine stamp of "VH171800". The number on the rear driver's side is 14016379. As near as I've been able to find it is a Mexico made crate motor from around 1978 that was made with both a 2 and a 4 bolt main.
NorCalC20LWB is offline   Reply With Quote
Old 04-07-2015, 05:04 PM   #11
leftybass209
You started to get me curious about mine as well again. What I found for yours is for the cylinder head #14079267.
Another forum cited this "per AERA manual for casting numbers.
14079267
14079261
14079287
14079267
79 to 86 350 chevy"
Old 04-08-2015, 06:34 PM   #12
shawno72
C/10 junkie
shawno72's Avatar
14079267
14079261
14079287
14079267
79 to 86 350 chevy"
Thanks guys. This confirms what I've been thinking, my "crate" engine is far older than I would like it to be
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-08-2015, 06:58 PM   #13
enaberif
There should be a 6 digit casting on the heads as well.. For example 333882 .. Should always be a 6 digit number.
Heads are replaceable and don't mean much unfortunately.
What is the number behind the driver side head under all the crud?
Old 04-10-2015, 09:26 PM   #14
shawno72
C/10 junkie
shawno72's Avatar
Ok update. The casting number on the back of the block is 14101148. Appears to be 86 and up 350 with a one piece read seal and roller cam I think
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-10-2015, 09:50 PM   #15
enaberif
Valve cover bolts.. do they go around the perimeter or down the center?
Old 04-10-2015, 09:52 PM   #16
shawno72
C/10 junkie
shawno72's Avatar
Around the perimeter. Here's some pics of what I found
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-11-2015, 11:41 AM   #17
NorCalC20LWB
Well now, that is odd. As mentioned above, my engine stamp on rear driver's side is 14016379, so according to your above post my engine is a 267?? Not even sure what that is! The year is correct (I think) and it does have the dipstick in the pan. Information overload....
Old 04-11-2015, 11:45 AM   #18
shawno72
C/10 junkie
shawno72's Avatar
Lol I know it's so confusing. I just spoke to the po and he told me that his dad replaced the engine somewhere between 98-02. Good news for me
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
