Dash with guages
Posted this up in the WIW forum but didn't get any input.
I picked this up a while back and installed it but have decided to go a different way. Everything works and it comes with the other end of the harness so that you can splice it into your existing wiring and make it plug & play. All gauges work, (Red) back-lighting works and comes with water temp and oil pressure sending unit. Comes with ABS plastic dash panel/bezel. Open to reasonable offers....
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Dash with guages
Do you know what the ohms range is on the fuel gauge? Is there a part number on the back of the gauge?
#3 | |
I believe it is a 90ohm gauge but when I get back to the house, I will verify. Reason I think it is a 90ohm is because the tank came from Pro Performance and they were using 90ohm sending units so I ordered the gauge to match IIRC. Will verify and get back to you.
60-66 Nut
Are you in need of any parts for your truck besides the firewall piece?
Posi with maybe 3.42 gears...
how about 200 plus the ride?
I'd be interested if you haven't already sold them
Posted via Mobile Device |
Still for sale.
I didn't see this earlier OF13SWC.
Sorry, can't do 200.
Still for sale?
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
#13 |
yes,
pm sent
#14 |
Sold.
