Old 04-24-2015, 04:00 PM   #1
Tilt
Original 86 electronic spark control wiring
Sorting through the original 86 wiring to get rid of what I no longer need. The 4 wire plug that went to the original distributor runs through the firewall and to what I believe is the electronic spark controller. It is bolted down behind the glove box. Will this box serve any purpose at all after the swap? I have seen a few people mount their LS PCM where this box is currently. There is a blue wire that went to a knock sensor, the 4 wires going to the distributor, and a heavy brown and heavy yellow wire that goes to a 2 prong connector that I do not know what it hooked up to. This heavy brown wire goes back to the spark control box, but the yellow wire jumps out of the loom and from the best I can tell runs over to the far drivers side under the dash and goes to a different 2 wire connector that has a Heavy purple wire that runs down to the fuse box. I will work on getting some photos. Should I be able to do away with all of this?
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 04-24-2015, 05:06 PM   #2
Tilt
Re: Original 86 electronic spark control wiring
Here is the box.
The yellow wire coming out of the this plug, jumps out of the bundle of wires above and runs to the drivers side.
The pink wire coming from the box goes to a fuselage link with the orange wire to the gray connector in the second photo above and the heavy pink wire then runs to the bulkhead connector here.
'85 GMC short bed.
Old 04-24-2015, 06:20 PM   #3
ls1nova71
ls1nova71's Avatar
You wont need any of that.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-24-2015, 06:32 PM   #4
Tilt
Thank you very much.
'85 GMC short bed.
