Old 04-27-2015, 07:44 PM   #1
jadedbird
jadedbird's Avatar
5.3/m20 muncie 4 speed bellhousing question
So I see most use the 621 BBC bellhousing. but wouldn't the gm 460486 bellhousing work with the ls7 throw out bearing, sach 1050 clutch kit, and 5.3 truck flywheel?
jadedbird is offline   Reply With Quote
Old 04-28-2015, 12:01 AM   #2
e015475
e015475's Avatar
Re: 5.3/m20 muncie 4 speed bellhousing question
The m20 is a car transmission ans has a 4 5/8 pilot This bellhousing is 5 1l8 so you need an adapter to use it
e015475 is offline   Reply With Quote
Old 04-28-2015, 03:55 AM   #3
jadedbird
jadedbird's Avatar
When I said ls7 throw out bearing. I ment ls7 pilot Bearing
Old 04-29-2015, 09:45 PM   #4
crazy longhorn
Fabricate till you "puke"
The LS 7 pilot bearing , works with the gen 1 clutch set up....I have a 1955 cast bell, on the back of my 2000 Ls 5.3. It is backed with a 6 spd Richmond, with standard mechanical clutch linkage. If you are going hydraulic, I cant help I did not play that? I used the sachs 1050 flywheel, with the gen I clutch setup. . 3 of the holes on the press plate, needed to be drilled /reamed carefully, about 1/64 inch (.015/.016). the Sachs flywheel, takes the metric bolts ....Use the ls1, ARP bolts, on the crank & the clutch hat. The flywheel bolts , go all thew (red loc tight to seal. On the bell housing, the last guy did not 'bull ****" you.....67 back, would fit the car trans...68 on, did not Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
