04-30-2015, 12:23 AM | #1 |
1971 C-10 knocking sound and not reving past 3000 RPM
I have a 1971 C-10 pickup and have recently found that the truck will not rev over 3000 RPM and when it gets to around 2800 RPM, an popping sound is made from under the hood. The motor is a 350 SBC with an Edelbrock 1406 carb and Edelbrock intake. Also the distributor has no points on it. Not quite sure what that means. Other than that the motor is stock, that I know of. The tranny in the truck is a TH400 which seems to be working fine. I have read that there can be many things causing the problems I have described with the 3 major ones being timing, spark plug gap, and compression. Right now I have the timing set at 12 degrees, a plug gap of .042 and the compression was between 9.1 to 8.5. I am not sure if that is too big of a difference. Also it appears that my motor is running way rich which I plan to fix going down the road as I don't have lots of money to spend. Maybe that has something to do with it? I don't know. Any help would be much appreciated because I am 15 and this is the first vehicle I have had to work on like this. Thanks.
04-30-2015, 07:16 AM | #2 |
Re: 1971 C-10 knocking sound and not reving past 3000 RPM
Welcome to the forum. There must be a couple of old gearheads in your area that would be willing to bring some tools over and give you a hand. You will get a bunch of ideas on what to check pretty soon. Do post a pic of your engine, air cleaner off, lots of good eyes out here.
04-30-2015, 09:40 AM | #3 |
Great, Thank you. I will post some pictures of the motor as soon as I can
04-30-2015, 10:35 AM | #4 |
Sounds like your timing chain and gears could be worn out and it jumped a few teeth. Had it happen myself a couple times and had the same symptoms.
http://smg.photobucket.com/albums/v655/aaronhero/ |
04-30-2015, 10:44 AM | #5 |
Do I need to replace the timing chain and gears in order to fix it, or is there another way to solve the problem? Thanks
04-30-2015, 10:51 AM | #6 |
Is this a recent issue or did you buy the truck this way? I think more details are needed before you go change a timing chain. It would be good to do a compression test on each cylinder. There is a tool you can borrow/rent if you don't have one. That would help confirm a timing chain and general condition of the engine. Is the engine recently rebuilt or original or what? Need a bigger picture of how you got to here.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
04-30-2015, 10:56 AM | #7 | |
Posted via Mobile Device |
04-30-2015, 11:02 AM | #8 | |
I ran a compression test on the motor last night. It was ranging from between 8.5 to 1 and 9.1 to 1 compression. I am fairly sure the motor came this way. I have only had the truck for about 6 months and have been slowly fixing problems on the truck. My first priority was putting in all new rotors, ball joints, etc and I have just now (past couple weeks) moved on to the drivetrain issues. The people that I bought the truck from said the truck's motor was rebuilt about 80,000 miles ago. I cannot recall how long ago this was done. I have little confidence in the mechanical state of the motor being ok as there have been several things on the motor that make it look like the motor was just thrown together, wiring is a mess, vacuum hoses were on incorrectly on the carb, kickdown switch was not working correctly (is fixed now.) I also do not know if the motor is the original since it has a TH 400. I read that the only way to get a TH 400 in my truck was to have 454 Big Block in my truck (don't know if that is accurate) which leads me to believe either the motor is not the original or the tranny is not the original. |
04-30-2015, 11:07 AM | #9 | |
04-30-2015, 11:16 AM | #10 | |
04-30-2015, 11:30 AM | #11 | |
04-30-2015, 11:32 AM | #12 |
Sorry for the typo at the beginning. I meant to say that I am pretty sure the distributor is not loose
04-30-2015, 11:49 AM | #13 |
Proprietor of Dale's Corner
It could be an exhaust valve causing the "popping" noise. Is the popping coming up the carb. What do you mean when you say compression test comes up 8.5 through 9.5 to 1. All gauges I own are in PSI not compression ratio.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-30-2015, 11:56 AM | #14 |
My apologies. I was getting between 8.5 to 9.1 Kg/Cm^2. I think that is around 125 PSI. I assumed that was the compression ratio, but maybe that was an incorrect assumption. And yes, it sounds like the popping sound is coming up the carb.
04-30-2015, 12:05 PM | #15 |
When you said you did a compression test it was 8.5 or 9.5, I think there is a misunderstanding or miscommunication here. To do a compression check you need a compression gauge and then you take out a spark plug and put the compression tester in the spark plug hole.Wit h the coil unhooked, you then crank the engine over with the starter for a couple of seconds. the gauge will then read compression in a number form like 125 psi. All of the numbers should be close to each other say6 the first was 125 then the rest should be between 100 and 140ish. You see if you have one that is real low say 60 or less it may not even be firing when its time too. The low compression will tell you if you have problems such as burned piston or broken piston stuck valves or other problems that could arise. Get a gauge and do the compression test then post up the results for all 8 cylinders then maybe we can better answer your question. Jim
04-30-2015, 12:21 PM | #16 |
Steady popping up the carb usually means something in the valve train. Exhaust/compression needing a way out. Common causes are bent push rod, bad rocker arm, bent valve or flat cam lobe.
04-30-2015, 12:25 PM | #17 | |
04-30-2015, 02:25 PM | #18 |
A wiped exhaust lobe will also cause it to pop out of the carb. If you pull the valve covers, you can watch the rockers compress the springs, while letting the engine idle. If any of them barely move compared to the others, bad cam lobe.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
04-30-2015, 06:51 PM | #19 |
Roadtrip!
I am guessing the cam may be going flat.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-30-2015, 08:10 PM | #20 |
heres an old mechanics trick my grandpa taught me about timing. drive the truck till about 30-45 MPH (just after it switches to gears) coast for a short distance and then accelerate quickly about 5 mph giving the engine load. if you hear pre ignition knock (sounds kind of like marbles in the engine) retard the timing a little bit and the entry again. if you don't hear a knock advance it little bit. retest till you hear the knock and the back it off just slightly. that will set your low end timing but for the high rpm advance you need to play with the springs and weights underneath the distributer cap. heavier weight/ lighter spring = timing advanced quicker. lighter weigh/ heavier spring = timing advance later on.
04-30-2015, 09:09 PM | #21 |
I hope to be home soon, then I will start on all the suggestions on figuring out what the problem is. Thanks for all the help. I had no idea where to start and now I have too many things to do and not enough time, which is definitely a good thing. Hope to test compression tonight and if pressure seems to be ok, I will move on to the distributor location, timing chain, and then watch the valves move to see if the cam is going out. Will update as much as I can
04-30-2015, 10:52 PM | #22 |
I just ran a compression test on the motor, here are the results.
#1 130 PSI #3 130 PSI #5 128 PSI #7 140 PSI #2 120 PSI #4 130 PSI #6 120 PSI #8 120 PSI Attached are some basic pictures of the motor. Also on the #8 Cylinder I noticed an unusual amount of black hard particles on the spark plug. I do not know what that is and have attached a photo of it. Thanks |
04-30-2015, 11:09 PM | #23 | |
05-01-2015, 12:44 AM | #24 |
20' Daredevil (Ret)
If that's not a collapsed lifter, it's probably a flat cam lobe.
05-01-2015, 08:35 AM | #25 |
x2
Tags |
350 chevy small block, popping, rpm, timing adjustment |
