Any pics of a blazer with a pick up tailgate? Thanks
Like to see some blazer pics with pick up tailgate. Thanks
I know the pieces fit
Re: Any pics of a blazer with a pick up tailgate? Thanks
Here's a few I found. Going soft top permanently?
'68 C10 SWB '85 K30 Blazer |
I do not have a permanent plan yet but I want to get some ideas. Thanks guys.
If you don't go soft top you can always modify a camper shell hatch to work. I am in the process of doing this now I finally got fed up with replacing tailgate windows from stock blazer latches popping open happened 3 times and the last time was in the snow which made for a rather cold ride home. This is only going to be a temporary fix for me though because I plan on getting a soft top.
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
Thanks for the info guy's. How hard is it to put a pick up tailgate on a blazer? What has to be done?
tis easy. You need different hardware though, but the parts are easy to get from Pick n pull for $20 and the mounting holes should already be there on the blazer.
It sounds like it will bolt right up without any cutting or mods.
That it does. Keep your original pieces and you can return it to stock later on if you want.
it took me 3 visits to the pick n pull to get a decent tailgate and the right hardware. Total cost $50. i have it on standby for a change from the correct tailgate.
Just make sure the tail gate and hardware are from the same "generation" of tail gates. I hear the trunions and hinges can be different from an early 70s to a later 80s. Best bet, just get it all from the same truck. Holes and threads are already in the blazer. They use the same fenders.
