Old 05-06-2015, 09:17 PM   #1
MalibuSSwagon
VSS Options
So working on gathering parts and pieces for my 5.3L swap. One issue I haven't quite tackled yet is the VSS. Right now I am going to reuse the factory SM465, this is a 2WD truck. I would like to stick with a 40 PPR VSS as I plan to swap to an NV4500 later on at some point, prehaps when my bank account recovers . What would be my best choice? Jags that run has the diff mounted tone ring, which seems like the best deal price wise. Next, Dakota Digital has a little bullet shaped unit which bolts right onto the cable drive from the transmission, but pricy for what it is and I couldn't run my mechanical speedo which I was planning to do until I go the truck re-geared.
Any other tricks you guys have?
MalibuSSwagon is offline   Reply With Quote
Old 05-07-2015, 11:38 AM   #2
dayj1
Re: VSS Options
You've got a pretty good handle on it. With your requirement to keep 40 pulses per driveshaft revolution and a mechanical speedo, the JTR tone ring is about the only game in town. Anything else that I can think of will cost you more and be more of a headache in the long run.
dayj1 is offline   Reply With Quote
Old 05-07-2015, 12:19 PM   #3
MalibuSSwagon
Re: VSS Options
I figured. I've done a lot of research on the subject. Basically I want to keep it 40 PPR so when I get the NV4500, I don't have to spend another $75 to have the PCM re-programmed. Any mechanical drive pass through solutions are out since I'll lose the mechanical drive at that point.
Old 05-08-2015, 11:08 PM   #4
Juiced06GTO
Re: VSS Options
I'm not familiar with the sm465, but on the th400 i had in my 87 I drove the VSS off the speedo cable. It just installed inline of the speedo cable and transmission and the speedometer in the truck still worked, I believe I used the Dakota Digital one. I know HP Tuners and EFI live are expensive up front, but if you are going to be doing swaps it may be worth investing in one of them so you can update whatever you need on your own.
Juiced06GTO is offline   Reply With Quote
